返信
Blind transfer always fails
hariskar
I can xfer a call to an internal number of my office (**621) without problems, but blind transfer to the same phone always fails. During dialing of the same internal number display shows "Transfer failed".
I have 2 cisco phones spa303 and spa504G. Blind transfer fails to both directions.
Do I have to change some settings?
Blind Transfer Serv is enabled. I have 1 line enabled in each phone.
Any help?
Than you!
9件の返信9
bijpraka
Whats the call control server you are using?
Is the Blind transfer service enabled on the server?
What the error messaging coming from the server when you do a blind transfer?
Thanks.
All phones are on Fritzbox 7590.
As far as I know, there is no option to enable/disable blind calls on Fritzbox.
There are no relevant messages in Fritzbox log.
Thank you for reply!
So when the transfer fails there is no incoming SIP message from the server?
I don''t see this kind of messages in Fritzbox log. In Telephony log there is only 1 message which is irrelevant:
Internet telephony with grafeio1 via 192.168.1.10:10150 failed. Cause: Temporarily not available (480) [2 messages since 24.05.19 08:04:25]
Edit: I think I found a way to see hidden  SIP messages, when I'll go to work I will see them and post.
Thank you!
Take a look at the phone logs as well to see if you can get a clue in that.
I will when I return to work. Till then could you please make some assumptions? Some possible causes?
Blind transfer is what I need more from IP phones..
I can't really say much without seeing the messaging. I would think the blind transfer service on the server is disabled.
In that case you would be getting a 403 to the REFER from the server.
Thanks.
Here is the syslog of the phone. I cleared just before bxfer. I hope this helps. I also attach the log of Fritzbox:
May 25 10:21:09	192.168.1.10	SDP	local2	debug		RTPMAP 102 --> 130
May 25 10:21:09	192.168.1.10	SDP	local2	debug		RTPMAP 100 --> 131
May 25 10:21:09	192.168.1.10	SDP	local2	debug		RTPMAP 99 --> 129
May 25 10:21:09	192.168.1.10	SDP	local2	debug		RTPMAP 97 --> 255
May 25 10:21:09	192.168.1.10	SDP	local2	debug		RTPMAP 101 --> 142
May 25 10:21:09	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:09	192.168.1.10	INVITE			sip:grafeio1@192.168.1.10:5060 SIP/2.0
SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK47B975FC232F2EDB From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF To: <sip:grafeio1@192.168.1.10:5060>;expires=3600 Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 163 INVITE Contact: <sip:C4A4C199895A79C69D685E3240603@192.168.1.1> Max-Forwards: 70 P-Called-Party-ID: <sip:2510620630@fritz.box> Expires: 120 Session-Expires: 600;refresher=uac Min-SE: 90 User-Agent: AVM FRITZ!Box 7590 154.07.10 (Apr 24 2019) Supported: 100rel,replaces,timer Allow-Events: telephone-event,refer Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH Content-Type: application/sdp Accept: application/sdp, multipart/mixed Accept-Encoding: identity Content-Length:   379  v=0 o=user 6820438 6820438 IN IP4 192.168.1.1 s=call c=IN IP4 192.168.1.1 t=0 0 m=audio 7078 RTP/AVP 8 0 2 102 100 99 97 101 18 a=sendrecv a=rtpmap:2 G726-32/8000 a=rtpmap:102 G726-32/8000 a=rtpmap:100 G726-40/8000 a=rtpmap:99 G726-24/8000 a=rtpmap:97 iLBC/8000 a=fmtp:97 mode=30 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=fmtp:18 annexb=no a=rtcp:7079 	Via
May 25 10:21:09	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{300)
May 25 10:21:09	192.168.1.10	SIP/2.0			100 Trying
<sip:grafeio1@192.168.1.10:5060>;expires=3600 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 163 INVITE Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK47B975FC232F2EDB Server: Cisco/SPA504G-7.6.2e Content-Length: 0  	To
May 25 10:21:09	192.168.1.10	>>>>	local3	debug	SIP	SIP_getRemotePartyId 0
May 25 10:21:09	192.168.1.10	ucCallerIdHeader	local3	debug		0 bUseFromOnly 0 bNoFrom 0 bPrivacy 0
May 25 10:21:09	192.168.1.10	SIP_getRemotePartyId(),	local3	debug		2 cinf->strPhone=6974900493
May 25 10:21:09	192.168.1.10		local3	debug		[SIP_getRemotePartyId] splash attr=0
May 25 10:21:09	192.168.1.10		local3	debug		[SIP_getRemotePartyId] try to call id_map
May 25 10:21:09	192.168.1.10	SIP_getRemotePartyId(),	local3	debug		4 cinf->strPhone=6974900493
May 25 10:21:09	192.168.1.10	SIP_getRemotePartyId(),	local3	debug		cinf->strPhone=6974900493
May 25 10:21:09	192.168.1.10	SIP_getRemotePartyId(),	local3	debug		cinf->strName=
May 25 10:21:09	192.168.1.10	<<<<	local3	debug	2 SIP	SIP_getRemotePartyId
May 25 10:21:09	192.168.1.10	+++++	local0	info		find idle call i = 0, caid=0 (asked 0)
May 25 10:21:09	192.168.1.10		local0	info		[0]CC:NewCallState 10/0
May 25 10:21:09	192.168.1.10		local3	debug		[CCTRL]record lcr phone=6974900493 exten=0 type=0
May 25 10:21:09	192.168.1.10	START_RING	local0	info		in CC_refresh
May 25 10:21:09	192.168.1.10	In	local1	debug		InitRemoteVoipMetrics
May 25 10:21:09	192.168.1.10	In	local1	debug		InitVoipMetrics
May 25 10:21:09	192.168.1.10		local2	debug		[0:0]AUD ALLOC CALL (port=16510)
May 25 10:21:09	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{367)
May 25 10:21:09	192.168.1.10	SIP/2.0			180 Ringing
<sip:grafeio1@192.168.1.10:5060>;expires=3600;tag=e3ec0eabf6b1b976i0 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 163 INVITE Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK47B975FC232F2EDB Contact: <sip:grafeio1@192.168.1.10:5060> Server: Cisco/SPA504G-7.6.2e Content-Length: 0  	To
May 25 10:21:12	192.168.1.10	PHN_setAudioPath(1)	local3	debug
May 25 10:21:12	192.168.1.10		local3	debug		[CCTRL]record lcr phone=6974900493 exten=0
May 25 10:21:12	192.168.1.10		local0	info		[0]CC:NewCallState 12/10
May 25 10:21:12	192.168.1.10	AUD_startRtpRx().	local2	debug		[0:0]. Port 16510. Ip 0x0. Tx txPayloadType 0.
May 25 10:21:12	192.168.1.10		local2	debug	AUD_startRtpRx	Grabbed new tcid 0
May 25 10:21:12	192.168.1.10	Codec	local2	debug	list
May 25 10:21:12	192.168.1.10	0	local2	debug
May 25 10:21:12	192.168.1.10	130	local2	debug
May 25 10:21:12	192.168.1.10	8	local2	debug
May 25 10:21:12	192.168.1.10	18	local2	debug
May 25 10:21:12	192.168.1.10	131	local2	debug
May 25 10:21:12	192.168.1.10	129	local2	debug
May 25 10:21:12	192.168.1.10	142	local2	debug
May 25 10:21:12	192.168.1.10	13	local2	debug
May 25 10:21:12	192.168.1.10	kosmos_update_dsp_channel_profile(tcid=0,	local2	debug		n=8, pucDpt=0x94993440, txPt=0)
May 25 10:21:12	192.168.1.10		local2	debug		[0:0]RTP Rx Up. tcid 0.
May 25 10:21:12	192.168.1.10	Respond	local0	info		200 OK in SIP_dlgSessCmdProc
May 25 10:21:12	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{695)
May 25 10:21:12	192.168.1.10	SIP/2.0			200 OK
<sip:grafeio1@192.168.1.10:5060>;expires=3600;tag=e3ec0eabf6b1b976i0 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 163 INVITE Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK47B975FC232F2EDB Contact: <sip:grafeio1@192.168.1.10:5060> Server: Cisco/SPA504G-7.6.2e Content-Length: 208 Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE Supported: replaces Content-Type: application/sdp  v=0 o=- 3849638 3849638 IN IP4 192.168.1.10 s=- c=IN IP4 192.168.1.10 t=0 0 m=audio 16510 RTP/AVP 0 101 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:30 a=sendrecv 	To
May 25 10:21:12	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:12	192.168.1.10	ACK			sip:grafeio1@192.168.1.10:5060 SIP/2.0
SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK0BF518AAAF188447 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF To: <sip:grafeio1@192.168.1.10:5060>;expires=3600;tag=e3ec0eabf6b1b976i0 Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 163 ACK Contact: <sip:C4A4C199895A79C69D685E3240603@192.168.1.1> Max-Forwards: 70 User-Agent: AVM FRITZ!Box 7590 154.07.10 (Apr 24 2019) Content-Length: 0  	Via
May 25 10:21:12	192.168.1.10		local2	debug		CC:Connected
May 25 10:21:12	192.168.1.10		local0	info		[0]CC:NewCallState 13/12
May 25 10:21:12	192.168.1.10	AUD_startRtpTx().	local2	debug		[0:0]. 192.168.1.1:7078. Local port 16510. Payload type 0. Payload size 0 ms.
May 25 10:21:12	192.168.1.10		local2	debug		c->ucState=13
May 25 10:21:12	192.168.1.10	ptime	local2	debug		adjusted to 30ms.
May 25 10:21:12	192.168.1.10	Already	local2	debug		have tcid 0
May 25 10:21:12	192.168.1.10	kosmos_update_dsp_channel_profile(tcid=0,	local2	debug		n=4, pucDpt=0x94993440, txPt=0)
May 25 10:21:12	192.168.1.10		local2	debug	ucId	0, bRtpTxEnable: 0, ucNumRtpTxEnable++: 1
May 25 10:21:12	192.168.1.10		local2	debug	isConference	0
May 25 10:21:12	192.168.1.10	Local	local2	debug	loopback mode	None. Type: None.
May 25 10:21:12	192.168.1.10	Remote	local2	debug	loopback mode	None. Type None.
May 25 10:21:12	192.168.1.10		local2	debug		[0:0]RTP Up (pt=0 dpt=0 16510->192.168.1.1:7078)
May 25 10:21:16	192.168.1.10		local0	info		[0]CC:NewCallState 15/13
May 25 10:21:16	192.168.1.10		local0	info		[1]CC:NewCallState 6/0
May 25 10:21:16	192.168.1.10		local2	debug		[1]Blind Xfer
May 25 10:21:16	192.168.1.10	AUD_stopRtpTx.	local2	debug		[0:0] tcid 0.
May 25 10:21:16	192.168.1.10		local2	debug	ucId	0, bRtpTxEnable: 1, ucNumRtpTxEnable--: 0
May 25 10:21:16	192.168.1.10		local2	debug		[0:0]RTP Tx Dn
May 25 10:21:16	192.168.1.10	####	local3	debug		create TS 1 0x949ed660
May 25 10:21:16	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{679)
May 25 10:21:16	192.168.1.10	INVITE				sip:C4A4C199895A79C69D685E3240603@192.168.1.1 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-e61841a2 From: <sip:grafeio1@192.168.1.10>;tag=e3ec0eabf6b1b976i0 To: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 101 INVITE Max-Forwards: 70 Contact: <sip:grafeio1@192.168.1.10:5060> Expires: 30 User-Agent: Cisco/SPA504G-7.6.2e Content-Length: 227 Content-Type: application/sdp  v=0 o=- 3849638 3849639 IN IP4 192.168.1.10 s=- c=IN IP4 0.0.0.0 t=0 0 m=audio 16510 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:30 a=sendonly
May 25 10:21:16	192.168.1.10	SDP	local2	debug		RTPMAP 101 --> 142
May 25 10:21:16	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:16	192.168.1.10	SIP/2.0			200 OK
SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-e61841a2 From: <sip:grafeio1@192.168.1.10>;tag=e3ec0eabf6b1b976i0 To: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 101 INVITE Contact: <sip:C4A4C199895A79C69D685E3240603@192.168.1.1> User-Agent: AVM FRITZ!Box 7590 154.07.10 (Apr 24 2019) Supported: 100rel,replaces,timer Allow-Events: telephone-event,refer Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH Content-Type: application/sdp Accept: application/sdp, multipart/mixed Accept-Encoding: identity Content-Length:   233  v=0 o=user 6820438 6820439 IN IP4 192.168.1.1 s=- c=IN IP4 192.168.1.1 t=0 0 m=audio 7078 RTP/AVP 0 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=recvonly a=rtcp:7079 	Via
May 25 10:21:16	192.168.1.10		local3	debug	RSE_DEBUG	rse_unref context: 0x949eda24
May 25 10:21:16	192.168.1.10	AUD_stopRtpRx.	local2	debug		[0:0] tcid 0.
May 25 10:21:16	192.168.1.10	AUD_stopRtpRx.	local2	debug		tcid 0 released.
May 25 10:21:16	192.168.1.10		local2	debug		[0:0]RTP Rx Dn
May 25 10:21:16	192.168.1.10	>>>>	local3	debug	SIP	SIP_getRemotePartyId 0
May 25 10:21:16	192.168.1.10	ucCallerIdHeader	local3	debug		0 bUseFromOnly 0 bNoFrom 1 bPrivacy 0
May 25 10:21:16	192.168.1.10	<<<<	local3	debug	1 SIP	SIP_getRemotePartyId
May 25 10:21:16	192.168.1.10	AUD_stopRtpTx.	local2	debug		[0:0] tcid -1.
May 25 10:21:16	192.168.1.10		local2	debug		CC:Remote Resume
May 25 10:21:16	192.168.1.10		local2	debug		CC:Hold
May 25 10:21:16	192.168.1.10		local0	info		[0]CC:NewCallState 14/15
May 25 10:21:16	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{400)
May 25 10:21:16	192.168.1.10	ACK				sip:C4A4C199895A79C69D685E3240603@192.168.1.1 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-88b2cd91 From: <sip:grafeio1@192.168.1.10>;tag=e3ec0eabf6b1b976i0 To: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 101 ACK Max-Forwards: 70 Contact: <sip:grafeio1@192.168.1.10:5060> User-Agent: Cisco/SPA504G-7.6.2e Content-Length: 0
May 25 10:21:17	192.168.1.10	+++	local0	info		ts 0x949943f0 clean 0 949ec6a0 949ec8d0 bcts:0 nRef:0
May 25 10:21:18	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{467)
May 25 10:21:18	192.168.1.10	SUBSCRIBE			sip:grafeio1@192.168.1.1 SIP/2.0
SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-cf949b11 From: <sip:grafeio1@192.168.1.1>;tag=b6f340ff1f175864 To: <sip:grafeio1@192.168.1.1> Call-ID: 22bc16dd-5a64f67d@192.168.1.10 CSeq: 1001 SUBSCRIBE Max-Forwards: 70 Contact: <sip:grafeio1@192.168.1.10:5060> Accept: application/x-broadworks-callpark-info+xml Expires: 1800 Event: x-broadworks-callpark User-Agent: Cisco/SPA504G-7.6.2e Content-Length: 0  	Via
May 25 10:21:18	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:18	192.168.1.10	SIP/2.0			489 Bad Event
SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-cf949b11 From: <sip:grafeio1@192.168.1.1>;tag=b6f340ff1f175864 To: <sip:grafeio1@192.168.1.1>;tag=0799D28FA8FE14DA Call-ID: 22bc16dd-5a64f67d@192.168.1.10 CSeq: 1001 SUBSCRIBE User-Agent: FRITZ!OS Content-Length: 0  	Via
May 25 10:21:18	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x94995960 event 27 state:1
May 25 10:21:18	192.168.1.10	SUBS	local2	debug		Failed 37 27 39
May 25 10:21:18	192.168.1.10	start	local0	info		TMR K
May 25 10:21:18	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x94995960 event 3 state:3
May 25 10:21:20	192.168.1.10	{sc}	local3	debug	dialapp blind xfer	**621
May 25 10:21:20	192.168.1.10		local2	debug		CC:BlndXferTgt:**621
May 25 10:21:20	192.168.1.10		local0	info		[1]CC:NewCallState 0/6
May 25 10:21:20	192.168.1.10	PHN_setAudioPath(0)	local3	debug
May 25 10:21:20	192.168.1.10		local2	debug		Calling:**621@192.168.1.1:0
May 25 10:21:20	192.168.1.10	####	local3	debug		create TS 1 0x949ec030
May 25 10:21:20	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{480)
May 25 10:21:20	192.168.1.10	REFER				sip:C4A4C199895A79C69D685E3240603@192.168.1.1 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-e45b630e From: <sip:grafeio1@192.168.1.10>;tag=e3ec0eabf6b1b976i0 To: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Referred-By: <sip:grafeio1@192.168.1.1> Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 102 REFER Max-Forwards: 70 Contact: <sip:grafeio1@192.168.1.10:5060> Refer-To: <sip:**621@192.168.1.1> User-Agent: Cisco/SPA504G-7.6.2e Content-Length: 0
May 25 10:21:20	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:20	192.168.1.10	SIP/2.0			400 Bad Request
SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK-e45b630e From: <sip:grafeio1@192.168.1.10>;tag=e3ec0eabf6b1b976i0 To: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 102 REFER User-Agent: FRITZ!OS Content-Length: 0  	Via
May 25 10:21:20	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x949ec030 event 27 state:1
May 25 10:21:20	192.168.1.10		local0	info		CC:TransferFailed
May 25 10:21:20	192.168.1.10	start	local0	info		TMR K
May 25 10:21:21	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x949ec030 event 3 state:3
May 25 10:21:23	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x94995960 event 9 state:3
May 25 10:21:23	192.168.1.10	Timer	local0	info		K Fires
May 25 10:21:23	192.168.1.10	+++	local0	info		ts 0x94995960 clean 0 94995910 949f04f0 bcts:1 nRef:0
May 25 10:21:23	192.168.1.10		local3	debug	RSE_DEBUG	rse_unref context: 0x94995d24
May 25 10:21:25	192.168.1.10	SIP_tsClientEventProc	local0	info		ts:0x949ec030 event 9 state:3
May 25 10:21:25	192.168.1.10	Timer	local0	info		K Fires
May 25 10:21:25	192.168.1.10	+++	local0	info		ts 0x949ec030 clean 0 949f0460 949ec000 bcts:1 nRef:0
May 25 10:21:25	192.168.1.10		local3	debug	RSE_DEBUG	rse_unref context: 0x949ec3f4
May 25 10:21:26	192.168.1.10	get	local0	info		new csrftokens<1c6c64ad>
May 25 10:21:30	192.168.1.10		local0	info		[0:5060]<<192.168.1.1:5060
May 25 10:21:30	192.168.1.10	BYE			sip:grafeio1@192.168.1.10:5060 SIP/2.0
SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK01038A295C0422B8 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF To: <sip:grafeio1@192.168.1.10:5060>;expires=3600;tag=e3ec0eabf6b1b976i0 Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 164 BYE X-RTP-Stat: CS=120;PS=872;ES=187;OS=139520;SP=0/0;SO=0;QS=-;PR=123;ER=665;OR=29520;CR=0;SR=0;QR=-;PL=0,0;BL=0;LS=0;RB=0/0;SB=-/-;EN=PCMU;DE=PCMU;JI=9,0;DL=0,0,0;IP=192.168.1.1:7078,[<illegal INADDR>] X-RTP-Stat-Add: DQ=1;DSS=0;DS=0;PLCS=1621904;JS=0 X-SIP-Stat: DRT=1;IR=0 Reason: Q.850; cause=16 Max-Forwards: 70 User-Agent: AVM FRITZ!Box 7590 154.07.10 (Apr 24 2019) Supported: 100rel,replaces,timer Allow-Events: telephone-event,refer Content-Length: 0  	Via
May 25 10:21:30	192.168.1.10		local0	info		[0:5060]->192.168.1.1:5060{316)
May 25 10:21:30	192.168.1.10	SIP/2.0			200 OK
<sip:grafeio1@192.168.1.10:5060>;expires=3600;tag=e3ec0eabf6b1b976i0 From: <sip:6974900493@fritz.box>;tag=7F99A2DE64A559FF Call-ID: FDECE56061B13480@192.168.1.1 CSeq: 164 BYE Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK01038A295C0422B8 Server: Cisco/SPA504G-7.6.2e Content-Length: 0  	To
May 25 10:21:30	192.168.1.10		local2	debug		[0:0]AUD Rel Call
May 25 10:21:30	192.168.1.10		local2	debug		CC:Ended
May 25 10:21:30	192.168.1.10		local0	info		[0]CC:NewCallState 0/14
May 25 10:21:32	192.168.1.10	+++	local0	info		ts 0x949ed660 clean 0 949ee860 949ef220 bcts:1 nRef:0
May 25 10:21:32	192.168.1.10		local3	debug	RSE_DEBUG	rse_unref context: 0x949eda24
Server is responding with 400 Bad Request in reply to the REFER sent from the device.
I guess you have to enable something on the server to either ensure that it understands REFER or enable blind transfer service there.
