03-26-2009 07:38 PM - last edited on 03-25-2019 07:49 PM by ciscomoderator
I have a client that wants to block all but one inbound calling number to a specific DID. Is there a way to exclude a number from a translation rule? For example. Could I do a rule that said:
voice translation-rule 1
rule 1 /5555551234/ /5555551234/
rule 2 reject /.*/
voice translation-profile BLOCK
translate calling 1
Dial-peer voice 100 voip
call-block translation-profile incoming BLOCK
destination-pattern 1111111111
I know the above does not work, but hopefully it helps get across what I am trying to accomplish. In short I want to block all calling numbers except for one that are destined for a specific dial-pattern.
Thank you in advance.
03-26-2009 09:30 PM
The problem with call-block is that works on incoming DPs only. Also, you do not use "reject" with a translation-rule used for call-block. finally, while you want to protect that certin DID, you allow all the rest. So, it's abit tricky, but try the following. 4321 is the protected DID, 5551234 the external calling number.
voice translation-profile my-block
translate called 100
voice translation-rule 100
rule 1 /4321/ //
dial-peer voice 10 pots
answer-address 5551234
incoming called-number .
direct-inward-dial
dial-peer voice 20 pots
direct-inward-dial
call-block translation-profile incoming my-block
03-27-2009 03:08 AM
Thank you for the quick response. Unfortunately that did not work. I see my call come in, but the inbound dial-peer that is being matched is always "10" regardless of the calling number.
I should also point out that I have an outbound dial-peer that is sending the call to UCM.
So as it currently stands I have 2 inbound dial-peers both with the same incoming called-number and one with a BLOCK rule and the other with the answer-address that I want to allow. I also have an outbound dial-peer with the destination pattern being a little more specific than the incoming called number on the afore mentioned dial-peers.
Any other ides?
