Block outbound calling numbers not withing number range on CUCM or CUBE
marcusdewaal
How can I allow a range of numbers, say from 1000 to 4999, to be allowed through the call manager and CUBE then block all other numbers from outside the range? I have CUCM 9.1 and a CUBE terminating the SIP provider.
Is it possible to use a translation-profile on the CUBE for this? Or is there a way to do this on the CUCM to allow a range based on calling number, but block all other calling numbers not within range from traversing the CUBE?
Marcus
Jaime Valencia
On CUCM you would need to make sure that you allow only those DNs to reach the RP to CUBE via CSS and partitions.
java
if this helps, please rate
