02-29-2016 08:03 AM - edited 03-17-2019 06:04 AM
I am trying to configure dial-peer to block calls to different extensions, the router already have configured the following
and configured to define that extencion nations can make calls or only extenciones
dial-peer cor custom
name internal
name AGC-local
name AGC-longdistance
name AGC-international
dial-peer cor list call-internal
member internal
dial-peer cor list AGC-call-local
member AGC-local
dial-peer cor list AGC-call-longdistance
member AGC-longdistance
dial-peer cor list AGC-call-international
member AGC-international
dial-peer cor list user-internal
member internal
dial-peer cor list AGC-user-local
member internal
member AGC-local
dial-peer cor list AGC-user-longdistance
member internal
member AGC-local
dial-peer cor list AGC-user-international
member internal
member AGC-local
dial-peer voice 1000 voip
description ***Unity-Express***
destination-pattern 2...
session protocol sipv2
session target ipv4:10.68.202.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 10 pots
translation-profile incoming Inbound-Calls
translation-profile outgoing outbound_calls
destination-pattern 9.T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .T
direct-inward-dial
port 0/0/0:1
dial-peer voice 100 voip
incoming called-number 1...
dial-peer voice 1001 voip
description ***Prompt-Management***
destination-pattern 2002
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1002 voip
description Main Number
destination-pattern 8700
dtmf-relay rtp-nte
codec g711ulaw
no vad
if they could help me i would appreciate it
Solved! Go to Solution.
03-02-2016 09:16 PM
If you share any configuration later on, please share as attachment ONLY.
As Mohit has mentioned before, you need to break your POTS dial peer if you want to apply separate restrictions to phones.
Considering following are your outbound dial peers;
destination-pattern 900T
corlist outgoing AGC-call-international
direct-inward-dial
port 0/0/0:1
dial-peer voice 100 pots
destination-pattern 90T
corlist outgoing AGC-call-longdistace
direct-inward-dial
port 0/0/0:1
dial-peer voice 1000 pots
destination-pattern (9[1-9]T)
corlist outgoing AGC-call-local
direct-inward-dial
port 0/0/0:1
Let say you want ephone-dn 1 to allow only local calls, then you need to assign respective corlist to ephone-dn 1 and doing so, this will restrict DN 1 to use only dial peer 1000 for outbound calls.
ephone-dn 1 <<only local calls and will select DP 1000>>
corlist inbound AGC-call-local
Similarly say ephone-dn 2 to allow only long distance calls;
ephone-dn 2 <<only long distance calls and will select DP 100>>
corlist inbound AGC-call-longdistance
Ephone-dn 3 to allow only international calls;
ephone-dn 3 <<only international calls and will select DP 10>>
corlist inbound AGC-call-international
By the way, you would like user to allow local and long distance calls also who are allowed to call international. In that case, you would change corlist as follows;
dial-peer corlist AGC-call-longdistance
member AGC-local
dial-peer corlist AGC-call-international
member AGC-local
- Vivek
03-07-2016 10:08 PM
Seems you have not configured 'id mac' command under pool, so configure that first before applying corlist.
- Vivek
02-29-2016 07:05 PM
More details please. Are you using CME, CUCM, SIP, SCCP?
03-01-2016 08:38 AM
Hi Mophammed, I use CME what I want is to give privileges to each extension, only some can make international calls
03-01-2016 09:01 AM
Hi Hector,
The dial peer for "10" is a general dial peer which will allow calls to local,national and international numbers. If you want to block some extension from making international calls then you need to create separate dial peer for international (900T), national (90T) or local (9[1-9]T) and assign the dial peer a cor list in outbound direction. For ex;
dial-peer voice <> pots
desc *** International calls***
Now only the phones with incoming COR list "AGC-user-international" will be able to make international calls.
ephone-dn 1
number XYZ
cor incoming AGC-user-international
Other phones which does not have this COR list will not be able to international call.
03-01-2016 05:03 PM
because try adding the corset on the dial peer voice 10 pots and I accepted the command but seeing settings did not show me the corlist
just to be sure the settings would be as follows:
direct-inward-dial
port 0/0/0:1
direct-inward-dial
port 0/0/0:1
direct-inward-dial
port 0/0/0:1
03-01-2016 10:05 PM
Did you also assign the correct corlist to ephone-dn (inbound dial peer)?
Please share the current show run and your exact requirement so that we can assist you accordingly.
- Vivek
03-02-2016 08:27 AM
This is the configuration that has the router:
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.0.0.0 255.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
h323
call start slow
sip
bind control source-interface GigabitEthernet0/0.20
bind media source-interface GigabitEthernet0/0.20
registrar server
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 2
call start slow
no telephony-service ccm-compatible
no ccm-compatible
voice class custom-cptone jointone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
voice register pool-type 8831
phoneload-support
num-lines 3
description SIP Phone 8831
reference-pooltype 6941
voice register global
mode cme
source-address 10.68.202.2 port 5060
max-dn 200
max-pool 100
load 7841 sip78xx.10-1-1SR1-4.loads
timezone 8
date-format D/M/Y
hold-alert
voicemail 2000
tftp-path flash:
file text
create profile sync 0002473102498826
camera
video
voice register dn 1
number 2801
call-forward b2bua busy 2000
call-forward b2bua noan 2000 timeout 18
name Sean Ohnishi
label Sean Ohnishi
voice register dn 2
number 2802
name Justino Salvador
label Justino Salvador
voice register dn 3
number 2850
name Sergio Gutierrez
label Sergio Gutierrez
voice register dn 4
number 2804
name Paulo Silva
label Paulo Silva
voice register dn 5
number 2805
name Don Gil Montoya
label Don Gil Montoya
voice register dn 6
number 2806
name Carlos Sanchez
label Carlos Sanchez
voice register dn 7
number 2808
label Kazuhito Hida x2808
voice register dn 9
number 70
name PAGING
label PAGING
voice register dn 10
number 2817
name Omar Alvarado
label Omar Alvarado
voice register dn 11
number 2832
name Gabriela Flores
label Gabriela Flores
voice register dn 12
number 70
huntstop
label PAGING
voice register dn 15
number 2815
name Israel Harrera
label Israel Herrera
voice register dn 16
number 2816
name Roberto Garcia
label Roberto Garcia
voice register dn 20
number 2820
name Mikio Takano
label Mikio Takano
voice register dn 21
number 2821
name Seigo Saito
label Seigo Saito
voice register dn 22
number 2822
name Enrique Plazola
label Enrique Plazola
voice register dn 30
number 2830
name Ivette Quintana
label Ivette Quintana
voice register dn 31
number 2831
call-forward b2bua all 2832
shared-line
label Monica Leyva
voice register dn 33
number 2833
name Amelia Moncada
label Amelia Moncada
voice register dn 35
number 2835
name Jorge de la Cruz
label Jorge de la Cruz
voice register dn 36
number 2836
name Hector Barrios
label Hector Barrios
voice register dn 65
number 2865
name SALA HUASTECA
label SALA HUASTECA
voice register dn 66
number 2866
name SALA XILITLA
label SALA XILITLA
voice register dn 67
number 2867
name SALA ALTIPLANO
label SALA ALTIPLANO
voice register dn 68
number 2868
name SALA TOLTECA
label SALA TOLTECA
voice register dn 69
number 2869
name SALA AZTECA
label SALA AZTECA
voice register dn 71
number 2871
name Spare 1
label Spare 1
voice register dn 72
number 2872
label Spare 2
voice register dn 73
number 2873
label Sala Maya Room
voice register dn 100
number 2875
name Guard House
label Guard House
voice register dn 110
number 2875
call-forward b2bua busy 2800
call-forward b2bua noan 2800 timeout 28
name Guard House
label Guard House
voice register pool 1
busy-trigger-per-button 2
id mac 5067.AEE2.D548
type 7841
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 2
id mac 5067.AEE2.D5B4
type 7841
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 3
id mac 5067.AEE2.D4BD
type 7841
number 1 dn 3
dtmf-relay rtp-nte
voice-class codec 1
username Sgutierrez password 12345
no vad
voice register pool 4
id mac 5067.AEE2.D574
type 7841
number 1 dn 4
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 5
id mac 5067.AEE2.D508
type 7841
number 1 dn 5
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 6
id mac 5067.AEE2.D46B
type 7841
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 7
id mac 1231.1234.1234
type 7841
voice-class codec 1
voice register pool 8
id mac 1839.1900.23D9
number 1 dn 9
dtmf-relay rtp-nte
username 70 password 1234
codec g711ulaw
no vad
voice register pool 9
type 7906
voice register pool 10
id mac 5067.AEE2.D397
type 7841
number 1 dn 11
voice-class codec 1
voice register pool 15
id mac 5067.AEE2.D530
type 7841
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 16
id mac 5067.AEE2.D557
type 7841
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 20
id mac 5067.AEE2.D486
type 7841
number 1 dn 20
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 21
id mac 5067.AEE2.D320
type 7841
number 1 dn 21
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 22
id mac 5067.AEE2.D4FB
type 7841
number 1 dn 22
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 30
id mac 5067.AEE2.D312
type 7841
number 1 dn 30
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 33
id mac 5067.AEE2.D475
type 7841
number 1 dn 33
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 35
id mac 5067.AEE2.D4A1
type 7841
number 1 dn 35
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 36
id mac 5067.AEE2.D415
type 7841
number 1 dn 36
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 65
id mac AC44.F212.0EE3
type 8831
number 1 dn 65
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 66
id mac AC44.F211.F9F8
type 8831
number 1 dn 66
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 67
id mac AC44.F212.2655
type 8831
number 1 dn 67
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 68
type 8831
number 1 dn 68
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 69
id mac AC44.F212.250B
type 8831
number 1 dn 69
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 71
id mac 5067.AEE2.D378
type 7841
number 1 dn 71
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 72
id mac 5067.AEE2.D2FE
type 7841
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice register pool 73
id mac 5067.AEE2.D47A
type 7841
number 1 dn 7
voice-class codec 1
username khida password 12345
voice register pool 100
id mac 5067.AEE2.D525
type 7841
number 1 dn 110
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
voice translation-rule 2
rule 15 /^\(....\)/ /4408702800\1/
voice translation-profile outbound_calls
translate calling 2
license udi pid CISCO2921/K9 sn FJC1849A1EG
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
vtp mode transparent
username ccongos privilege 15 password 7 03500E2C0A0022471D50
username logicalis privilege 15 secret 5 $1$j5NB$ayySV3ATWt/1DGNAB3Srg1
username admin privilege 15 secret 5 $1$HUR8$giM.ZaAu9cjNOSnYpj3du.
redundancy
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-22 type r2-digital r2-compelled ani
cas-custom 1
country telmex
category 2
answer-signal group-b 1
caller-digits 4
dnis-digits min 4 max 13
dnis-complete
timer interdigit incoming 1000
groupa-callerid-end
no ip ftp passive
interface Embedded-Service-Engine0/0
no ip address
shutdown
description Connection to Core
no ip address
duplex auto
speed auto
encapsulation dot1Q 20
ip address 10.68.X.X 255.255.255.0
interface ISM0/0
description Cisco Unity Express Voicemail
ip unnumbered GigabitEthernet0/0.20
service-module ip address 10.68.202.3 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.68.202.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:GUI
ip route 0.0.0.0 0.0.0.0 10.68.202.1
ip route 10.68.X.X 255.255.255.255 ISM0/0
ixi transport http
response size 4
no shutdown
request outstanding 1
ixi application cme
shutdown
snmp-server community AGCAApublic RO
snmp-server community a6c5nmp RW
tftp-server flash0:Analog1.raw
tftp-server flash0:Analog2.raw
tftp-server flash0:AreYouThere.raw
tftp-server flash0:AreYouThereF.raw
tftp-server flash0:Bass.raw
tftp-server flash0:CallBack.raw
tftp-server flash0:Chime.raw
tftp-server flash0:Classic1.raw
tftp-server flash0:Classic2.raw
tftp-server flash0:ClockShop.raw
tftp-server flash0:DistinctiveRingList.xml
tftp-server flash0:Drums1.raw
tftp-server flash0:Drums2.raw
tftp-server flash0:FilmScore.raw
tftp-server flash0:HarpSynth.raw
tftp-server flash0:Jamaica.raw
tftp-server flash0:KotoEffect.raw
tftp-server flash0:MusicBox.raw
tftp-server flash0:Piano1.raw
tftp-server flash0:Piano2.raw
tftp-server flash0:Pop.raw
tftp-server flash0:Pulse1.raw
tftp-server flash0:Ring1.raw
tftp-server flash0:Ring2.raw
tftp-server flash0:Ring3.raw
tftp-server flash0:Ring4.raw
tftp-server flash0:Ring5.raw
tftp-server flash0:Ring6.raw
tftp-server flash0:Ring7.raw
tftp-server flash0:RingList.xml
tftp-server flash0:Sax1.raw
tftp-server flash0:Sax2.raw
tftp-server flash0:Vibe.raw
tftp-server flash0:moh.au
tftp-server flash0:SCCP6911.9-2-1-a.loads
tftp-server flash0:SCCP6901.9-2-1-a.loads
tftp-server flash0:KNL6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:KNL6901SCCP.9-2-1-a.zz.sgn
tftp-server flash0:BFS6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:APP6911SCCP.9-2-1-a.zz.sgn
tftp-server flash0:APP6901SCCP.9-2-1-a.zz.sgn
tftp-server flash0:sip78xx.10-2-1-12SR1-4.loads
tftp-server flash0:sboot78xx.10-2-1-12SR1-4.sbn
tftp-server flash0:rootfs78xx.10-2-1-12SR1-4.sbn
tftp-server flash0:kern78xx.10-2-1-12SR1-4.sbn
tftp-server flash0:SCCP69xx.9-4-1-3SR1.zz.sgn
tftp-server flash0:SCCP69xx.9-4-1-3SR1.loads
tftp-server flash0:DSP69xx.12-4-122-99.131025.zz.sgn
access-list 50 permit 10.68.202.3
access-list 50 permit 10.68.202.0 0.0.0.255
access-list 50 remark -=[Control CUCME Web Access]=-
control-plane
voice-port 0/0/0:1
cptone MX
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
name internal
name AGC-local
member internal
member AGC-local
member internal
member internal
member AGC-local
member internal
member AGC-local
member internal
member AGC-local
dtmf-relay rtp-nte
codec g711ulaw
no vad
direct-inward-dial
port 0/0/0:1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:10.68.202.2 expires 3600 port 5060 transport udp unsolicited
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
authentication credential cisco cisco
authentication credential admin cisco
max-ephones 100
max-dn 200
ip source-address 10.68.202.2 port 2000
auto assign 1 to 100
auto assign 1 to 100 type 6921
system message ***CHANGE-ME***
url directories http://10.68.202.2/localdirectory
url services http://10.68.202.3/voiceview/common/login.do
url authentication http://10.68.202.2/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 6921 SCCP69xx.9-4-1-3SR1
load 6901 SCCP6901.9-2-1-a
time-zone 8
date-format dd-mm-yy
keepalive 60
voicemail 2000
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh enable-g711 "flash0:moh.au"
web admin system name admin password cisco
web admin customer name customer secret 5 $1$UcnC$f1n7y2zPLcAJ7e4gClSZ.1
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys hold Newcall Resume
softkeys idle Newcall Redial Cfwdall Dnd
softkeys seized Redial Endcall Cfwdall
softkeys alerting Endcall
softkeys connected Hold Endcall Trnsfer Confrn
keepalive 60
type 7960
ephone-dn 1
number 2881
label Recibo - 2881
description Recibo - 2881
ephone-dn 2
number 2860
label Carlos Chavira
description Carlos Chavira
call-forward busy 2000
call-forward noan 2000 timeout 18
ephone-dn 3 dual-line
number 2823
label Arturo Campos
description Arturo Campos
name Arturo Campos
ephone-dn 4 dual-line
number 2818
label Emilio Romero
description Emilio Romero
ephone-dn 5 dual-line
number 2861
label Maria Villalpando
description Maria Villalpando
ephone-dn 6
number 2834
label Nurse
description Nurse
ephone-dn 7 dual-line
number 2851
label Ana Palau
description Ana Palau
ephone-dn 8 dual-line
number 2852
label Homero Meneses
description Homero Meneses
ephone-dn 9 dual-line
number 2853
label Ivan Rodriguez
description Ivan Rodriguez
name test
ephone-dn 10 dual-line
number 2854
label QA Lab
description QA Lab
ephone-dn 11
number 2882
label Shipping - 2882
description Shipping
name Shipping
call-forward noan 2000 timeout 10
hold-alert 30 originator
ephone-dn 12
number 2904
label Layup - 2904
description Layup
ephone-dn 13 dual-line
number 2862
label Maria Jose Villalpando
description Maria Jose Villalpando
ephone-dn 14 dual-line
number 2900
label C&G
ephone-dn 15 dual-line
number 2906
label NIP
description NIP-2906
ephone-dn 16 dual-line
number 2905
label Loading
description Loading - 2905
ephone-dn 17 dual-line
number 2901
label Printing
description Printing-2901
ephone-dn 18 dual-line
number 2902
label Palletizing
description Palletizing-2902
ephone-dn 19 dual-line
number 2883
label Warehouse
description Warehouse-2883
ephone-dn 20 dual-line
number 2907
label FINAL INSPECTION
description FINAL INSPECTION
ephone-dn 21 dual-line
number 2870
label 2870
description IT Room - 2870
ephone-dn 22 dual-line
number 2837
label Veronica Fuentes
description Veronica Fuentes
ephone-dn 23 dual-line
number 2807
label Oswaldo Guerrero
description Oswaldo Guerrero
ephone-dn 24 dual-line
number 2824
label Cristhian Martinez
description Cristhian Martinez
ephone-dn 25 dual-line
number 2878
label Maintenance
description Maintenance
name Maintenance
ephone-dn 26 dual-line
number 2809
label Alan Vazquez
description Alan Vazquez
name Alan Vazquez
ephone-dn 27 dual-line
number 2876
label Cafeteria
description Cafeteria
ephone-dn 28 dual-line
number 2838
label Janette Lopez x2838
description Janette Lopez x2838
name Janette Lopez
call-forward noan 2000 timeout 38
ephone-dn 29 dual-line
number 2910
label Recepcisn x2910
description Recepcisn x2910
ephone-dn 30 dual-line
number 2813
label Temporal
description Temporal
ephone-dn 31 dual-line
number 2810
label Receptionist
description x2810 Receptionist
call-forward busy 2800
call-forward noan 18 timeout 18
ephone-dn 40
number 2840
label Logicalis Test
description 440-870-2840
name Nick
ephone-dn 100
number 1000....
mwi off
ephone-dn 101
number 1001....
mwi on
ephone 1
mac-address E0D1.730A.9830
max-calls-per-button 2
type 6901
button 1:1
ephone 2
mac-address 8480.2D77.7EEB
type 6901
button 1:11
ephone 3
mac-address 0C27.24BB.3429
type 6921
button 1:2
ephone 4
mac-address 0C27.24BB.3423
username "Acampos"
type 6921
button 1:3
ephone 5
mac-address E0D1.730A.985B
type 6901
button 1:18
ephone 6
mac-address E0D1.730A.9A7C
type 6901
button 1:14
ephone 7
mac-address E0D1.730A.9A08
type 6901
button 1:12
ephone 8
mac-address E0D1.730B.EA38
type 6901
button 1:20
ephone 9
mac-address 0227.24BB.3423
type 6921
ephone 10
mac-address 0C27.24BB.049B
type 6921
button 1:9
ephone 11
mac-address 44AD.D9BC.3C3B
type 6921
button 1:6
ephone 12
mac-address 0C27.24BB.157E
type 6921
button 1:4
ephone 13
mac-address 0C27.24BB.04B4
type 6921
button 1:7
ephone 14
mac-address 0C27.24BB.1571
type 6921
button 1:8
ephone 15
mac-address E0D1.730A.9572
type 6901
button 1:27
ephone 16
mac-address A493.4CBF.EB48
type 6921
button 1:2
ephone 17
mac-address E0D1.730A.9B0D
type 6901
button 1:15
ephone 18
mac-address E0D1.730A.99A3
type 6901
button 1:16
ephone 19
mac-address 5CFC.665C.F8F3
type 6901
button 1:17
ephone 20
mac-address 0C27.24BB.1614
type 6921
button 1:19
ephone 21
mac-address 0C27.24BB.1488
type 6921
button 1:22
ephone 22
mac-address A493.4CBF.EB38
username "oguerrero"
type 6921
button 1:23
ephone 23
mac-address A493.4CBF.EB6D
username "cmartinez"
type 6921
button 1:24
ephone 24
mac-address D48C.B527.EC41
username "Maintenance"
type 6921
button 1:25
ephone 25
mac-address A493.4CBF.EB68
username "QALaB"
type 6921
button 1:10
ephone 26
mac-address A493.4CBF.ECB1
username "avazquez"
type 6921
button 1:26
ephone 27
mac-address A493.4CBF.CAE8
username "jlopez"
type 6921
button 1:28
ephone 28
mac-address D48C.B527.EB1E
username "Receptionist"
type 6921
button 1:31
ephone 29
mac-address A493.4CBF.EB5B
type 6921
button 1:30
ephone 40
mac-address 40A8.F064.739E
type CIPC
button 1:40
ephone 100
ephone 110
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 60 0
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp master 3
ntp server 10.68.207.2
end
03-02-2016 09:16 PM
direct-inward-dial
port 0/0/0:1
direct-inward-dial
port 0/0/0:1
direct-inward-dial
port 0/0/0:1
member AGC-local
member AGC-local
- Vivek
03-04-2016 04:59 PM
Hi Vivek
and started to create the dial-peer, the command if I accept them in ephone-dn but in the voice register dn command does not want me
I have to change all phones registered as voice register to ephone-dn
or is there another way to restrict calls
03-04-2016 09:04 PM
Check under voice register pool.
- Vivek
03-07-2016 09:06 AM
vivek a question, does not command me tells me
Router(config-register-pool)#cor incoming AGC-call-longdistance default
Please configure voice-register-pool id first
which it is what I have bad
03-07-2016 10:08 PM
- Vivek
03-08-2016 11:02 AM
thanks vivek you can now configure
03-08-2016 09:02 PM
Thanks for updating us back Hector.
- Vivek
03-14-2016 09:05 AM
Hi vivek
I was a problem with the configuration of the dial-peer
because I set the dial-peer as follows, but without changing the dial-peer 10 which is what gives them permission to make calls
You think does not work because I need to modify settings dial-peer 10
the ephone-dn that desire that has only local calls is the ephone-dn 28
dtmf-relay rtp-nte
codec g711ulaw
no vad
direct-inward-dial
port 0/0/0:1
dial-peer voice 103 pots
corlist outgoing AGC-user-longdistace
direct-inward-dial
port 0/0/0:1
dial-peer voice 1004 pots
destination-pattern 9[1-9]T
corlist outgoing AGC-user-local
direct-inward-dial
port 0/0/0:1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
ephone-dn 28
