Bogen Tam-B rings a few times before picking up
jing_nghik
We implemented tam-b at many locations and there is one particular location that the tab-b picks up, but it doesn't pick up fast enough. Takes about 3-4 rings. Is there a way to make the ring pick up faster then that. I was told to increase the ring voltage.
This device is connected through an FXS interface. This is the same setup as other sites.
bgrunewald
Check the position of Aux switch S3 on the top of the unit. S3 OFF increases the time before the TAM-B answers in "station" (FXS) mode.
