BPX system config
Mesrop
Hello.
I want to setup BPX system with only switch.How can i do that?
And what kind switches support BPX configs?
Jaime Valencia
I guess you mean you want CME, if so, your need an ISR.
Your switch will only work to plug in your ip phones.
I strongly suggest you reach to a local reputable consultant or a local Cisco Partner with UC specializations so you can discuss your needs and then get suggestions on what would be needed to accomplish that.
java
if this helps, please rate
Jaime Valencia
java
Thank you!
