09-25-2018 04:35 AM - edited 03-17-2019 01:31 PM
Hi to all,
I have one IP phone CP-8845 that failed to upgrade and now is stuck on Cisco logo screen with some of speeddials green, sometimes top three and fourth amber, sometimes only three green or four green...but never all five of them.
There is no network activity at all, so I made console cable to see what happens:
It is stuck on this:
[SEC_STOR] Read KS (0, 540000, 1)
[SEC_STOR] use OTP value for new version
Version is:
"Welcome to BigEasy Video
(none) login: sdump: PID = 407
1 - Cisco Systems - # RELEASE Model=8845_65 Version=sip8845_65.12-1-1SR1-4"
Factory reset does not help, and I notice that if I press star (*) while booting up it load previous version of firmware:
(none) login: 1 - Cisco Systems - # RELEASE Model=8845_65 Version=sip8845_65.12-0-1SR1-1 "
but also stuck on same lines:
Then after some time reboots and stuck again with same message.
I also noticed that with zero pressed while powering, boot stops for a while with this:
"Hit any key to stop autoboot: 3
key '0' pressed "
But don't have a clue for what purpose is this.
Is there any solution to re-flash this phone in this state?
10-08-2020 12:17 AM
10-15-2020 01:55 AM
nope. I didn't find any solution for this other than replacing a phone with new one.
10-20-2020 02:55 AM
I've had some success by connecting the bricked phone to an isolated network with separate DHCP and pointing TFTP to my PC. Then stick whatever load file you want into the TFTP folder. You need to check on file names and structures for the particular model, and you can check with Wireshark to see if the phone's actually trying.
