Bulk Admin and Subscribe/Unsubscribe
cowetacoit
Does anyone know of a quick way to Subscribe/Unsubscribe a large number of phones from a Phone Service? I assuming there is something under the Bulk Adminitration tool but i can't seem to find anything.
Thanks!
testeven
You need to create a phone template first and then use BAT. Please refer to:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/8_0_2/t03phtmp.html#wp1188941
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Marwan ALshawi
create a phone template in BAT which has full list of services you wanted to add on the phones.
Then go to Bulk Admin, Phones, Update Phones, Query... select your device pool and hit 'Find...'.
When you have the correct list of phones displayed that you want to update, click 'Next'. At the bottom of the page, there should be a section that allows you to apply the list of services from any phone template. Select the phone template, and the services will be added.
Assign IP Phone Services
Add All Services From This Template
From the drop-down list box, choose the template that contains list of services that you want to update the phones with.
You can click the Edit IP Phone Service link to update the subscribed Cisco IP phones services on the template.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03updph.html#wp1342091
if helpful rate
