10-22-2021 05:51 AM - edited 10-22-2021 05:58 AM
Has anyone used this feature successfully? The sample file Cisco gives on CUCM doesn't have much information so I am wondering if the tool carries over all settings from the old phone to the new phone (Device Pool, CSS, Display Name, etc.)
Thanks in advance. All replies rated
Solved! Go to Solution.
10-22-2021 07:06 AM - edited 10-22-2021 07:09 AM
Are you in a process of replacing the old phones with new phones ? If yes, and if your CUCM versions is 11.5SU8 , or 12.SU3 or 14. You can make use of the Phone migrations feature. Which is a simple and easy process. Refer the below link to learn more about Phone migrations. You can also refer feature configuration Guide.
https://video.cisco.com/video/6192439545001
If its all about using import/export option, As JAVA mentioned, there are lot of content available over the community and internet regarding this topic.
Below mentioned are link to Cisco document and Cisco community live event on how to use Import/Export.
https://www.youtube.com/watch?v=iIpJ8vHKV1M
10-22-2021 06:42 AM
It will all depend on exactly what you're trying to do, the topic has been covered many times at the community, there's also the BAT documentation online (as well as the built-in help) and there was an ask me anything event on BAT that is also in the community. Have you reviewed any of those resources?
10-22-2021 06:58 AM
I'm trying to take some 79xx phones and migrate them to 8851 phones
10-22-2021 07:28 AM
Exactly what I was looking for. Thanks!
