Bulk administration tool configuration
monasir
Hi everyone,
I was wondering if it's possible to import a bulk in CUCM so that i can see the following at one time
This is what i want:
import all the mac adresses, css's ( different ) extension numbers callpickupgroups.
Maybe someone has a good solution
Do i need excel sheet format?
Craig Dyer
Level 3
Level 3
Good Morning,
     You can easily bulk import phones with different MAC address, CSS, DN, pickup groups ect ect ect..........
     Have a look at the the BAT guides:-
     http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/8_6_1/bat-861-cm.html
     On the CUCM there is a template spreadsheet that helps build the required format, look under:-
     Bulk Administration, Upload/Download files and download the bat.xlt file.
     The bat.xlt is only supported on Excel 32bit
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
