09-15-2015 04:38 AM - edited 03-17-2019 04:18 AM
Using CUCM 8.5.1 Is the only way to bulk edit directory numbers after they have been created is to export them via "Bulk Administrator"?
I have a range of numbers 78xxx - 78999 that I need to have the boxes checked for "Call forward and Call pickup settings" This was not done at the time of creation, however now I have several voicemail only accounts that cannot be reached internally(when dialed I get a fast busy). In that range I also have accounts that are voicemail and directory as in the number is on the phone. I tried to delete 5 of them under Call Routing/Directory Number as a test and one of the numbers that was on a phone was also deleted when I checked it under Device/Phone. If I delete and recreate them all I will have about 150 of them that I would have to go onto each phone and recreate, which is what I'm trying to avoid.
09-15-2015 05:04 AM
if you only intend to check the boxes for these lines then it can be done without export / import option. You can use the Bulk Administration > Phones > Add/Update Lines > Update Lines option. Please check and let me know if you have any questions.
Manish
- Do rate helpful posts -
09-15-2015 05:11 AM
I just solved my issue thanks. I needed to go Route Plan Report and delete unassigned directory numbers then from there, recreate them. Deleting from there left the assigned numbers alone.
