04-28-2011 06:25 AM - edited 03-16-2019 04:42 AM
Is there any chance to set the line-parameter "Busy-Trigger" smaller than 2.
With CUCM 8.5 und 7.1.5 you can set the value to 2. We need to change it to 1.
So I need some help!!!
Martin
08-22-2012 03:10 AM
Hi everyone,
We're hitting this bug and we've realized the following:
- with 9.1.2 we can't change the busy trigger value
- with 9.2.2 we can change the busy trigger value (the bug is fixed)
- with 9.3.1 again we can't...
This seems to be what happened to Fabian, doesn't it?
Shouldn't firmware newer than the one with the fix include the fix?
09-06-2012 06:12 AM
We are on 9.2.3.5 now and the busy trigger option works.
We fixed it by rebooting the whole cucm-cluster. So it was not a problem with our cucm-server or the firmware files or the devices.
Fabian
