08-18-2009 10:11 PM - edited 03-18-2019 10:31 AM
We recently upgraded to CUCM 6.1.3(b) from 4.X. Now, we receive a buzzing kind of sound when the speakers are turned on-on a call. We tried upgrading the firmware of 7941G from SCCP41.8-4-2S to SCCP41.8-4-4S. But, we still have the same issue. Can you pl suggest solution.
Regds
Karthik
Solved! Go to Solution.
08-19-2009 04:36 AM
Hi Karthik,
You may be hitting this bug;
CSCsz68389 Bug Details
Noise Reduction causes saturated speech on Handsfree Send
Symptom:
When talking on the speakerphone, far end listeners may hear voice clipping. The talker's voice may sound like a buzz.
Conditions:
This issue is most noticeable when the talker is using the speakerphone.
Workaround:
The talker can sit farther away from the phone, talk in a lower voice or use the handset or headset.
Further Problem Description:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Cisco Unified IP Phones 7900 Series
Technology
1st Found-In
8.5(2)
Fixed-In
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Hope this helps!
Rob
08-19-2009 04:36 AM
Hi Karthik,
Symptom:
Conditions:
Workaround:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 2 weeks
Product
Technology
1st Found-In
8.5(2)
Fixed-In
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Hope this helps!
Rob
08-19-2009 04:46 AM
Thanks Rob.
I have CCO credentials to download. Can u pl provide the link for
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
Thanks & Regds
Karthik
08-19-2009 09:11 AM
Hi Rob,
We could not find the version(Fixed in) in cisco. So we are raising a case with them to sought this out.
Thank u.
Regds
Karthik
