07-15-2020 07:40 PM
Hi Guys,
Can I check can I use C3925-CME-SRST/K9 model to support 700 users for the voice?
As currently we only support 200 users and we are moving into new building or should we replace it with a new model?
Solved! Go to Solution.
07-16-2020 04:28 AM
So if it is just a gateway, actually the one who determine the amount of IP phone can be use is the CUCM system in our data center, correct? YES
So voice gateway 3925 just route traffic and nothing to do with the amount IP phone it can support, right? no. it can also be used for SRST. in that case the number of phones registering during the SRST depend on the router capacity. I am not sure if the gateway is acting as both gateway and SRST router.
So if we move to new office, we still can use existing 3925 as the voice gateway right even though our user increase to 700 people instead of current of 200. if you are using the 3925 as a voice gateway and not using SRST feature, to cover the additional users you just need to add required license in CUCM . if you plan to use the router for both VG and SRST, you need consider the router capacity and SRST license on gateway.
07-15-2020 07:45 PM
Please refer below link.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme12spc.html
07-15-2020 09:14 PM
Thanks a lot for the link.
It seems 3925 model can only support 250 IP phone.
So if got 700 users, how should we go about it as I don't see a model which can support such amount of IP phones.
Thanks in advance.
07-15-2020 10:11 PM
Go with a BE6K. More informations on below link.
https://www.cisco.com/c/en/us/products/unified-communications/business-edition-6000/index.html
07-16-2020 12:46 AM
07-15-2020 10:19 PM
By the information provided I assume you are using CME. If so a 4431 should be what you need. It can if I remember correctly handle 1000 devices.
07-16-2020 12:51 AM
07-16-2020 02:06 AM - edited 07-16-2020 02:06 AM
correct me if I am wrong. asper your last reply, you are using CUCM in Data center and 3925 is used as voice gateway. you are moving this voice gateway to new location.
07-16-2020 03:33 AM
07-16-2020 04:28 AM
07-16-2020 10:19 AM
I strongly suggest you reach out to a reputable consultant or a Cisco partner WITH voice specializations to further discuss this.
If you're increasing the amount of users/devices, does the OVA support that?
Do you need to add redundancy on CUCM? Would you need CoW?
Have you accounted for the necessary BW required for the new devices?
Have you taken into consideration if more media resources are needed?
Does the GW has enough capacity for the amount of PSTN calls you would need with 700 users?
Do you need SRST, and if so, for how many users?
07-23-2020 12:53 AM
Thanks a lot all. Appreciate it.
I think looking for the consultant in this voice would be better as I'm newbie in this current setup.
07-16-2020 10:01 AM - edited 07-16-2020 10:03 AM
@ciscoguy88 wrote:
I check 4431 can support up total 350 IP phones only.
Your right, I had it mixed up with number of devices supported for SRST. For a 4431 that would actually be 1200.
