03-05-2013 12:11 AM - edited 03-16-2019 04:04 PM
Dear Concern,
We procure a C3945-CME-SRST/K9 with 2 more FL-CME-SRST-100 license. We have ordered the both in a single order. Now we are seeing this bellow out put in router.
Feature: cme-srst Period left: 8 weeks 3 days
Index: 1 Feature: cme-srst Version: 1.0
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 3 days
Period used: 3 minutes 6 seconds
Transition date: May 04 2013 07:47:01
License Count: 240/0 (In-use/Violation)
License Priority: Low
Store Index: 7
Store Name: Built-In License Storage
License type should be Parmannent with more linecse count.
03-05-2013 12:23 AM
Hi Banik,
Did you issue license accepy end user agreement command in router ? After u do that License Type : EvalRightTOUse should change to RightTOUse.
regds,
aman
03-05-2013 01:28 AM
Dear all,
Yes i have already done your advice process.The bellow out put
Store Index: 7
came after doing bellow process
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
My question is, i have procure CME-SRST bundle which should come with 25 CME-SRT license by default and license type should be parmanent.
Do i need to configure license for my rest license (FL-CME-SRST-100) ?
why it is showing
License Type: EvalRightToUse even after executing license accept end user agreement steps.
Pls advice.
03-05-2013 12:51 AM
Hello Banik,
Kindly find the details below. This should help you with all your queries / issues with regards to licensing.
Activating CME-SRST Feature License
The ISR G2 comes with a 60-day evaluation license. After 60 days, the license changes to "right to use". The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Note CME-SRST RTU license is introduced in Cisco IOS release 15.1(3)T and higher.
Prerequisites
•UCK9 license
•ISR G2 already accepts UC CLIs
•CME-SRST feature must be configured
SUMMARY STEPS
4. exit
6. write mem
DETAILED STEPS
| Command or Action | Purpose |
Step 1 | show license detail cme-srst Example: Router# show license detail cme-srst | Displays the available cme-srst license. EULA should be in NOT ACCEPTED state. |
Step 2 | configure terminal Example: Router# configure terminal | Enters global configuration mode. |
Step 3 | license accept end user agreement Example: Router(config)# license accept end user agreement | Configures a one-time acceptance of the EULA for cme-srst license. Accepts EULA by typing YES. |
Step 4 | exit Example: Router(config)# exit | Exits global configuration mode. |
Step 5 | show license detail cme-srst Example: Router# show license detail cme-srs | Displays the available cme-srst license. EULA should be in ACCEPTED state. |
Step 6 | write mem Example: Router# write mem | Saves configuration. |
Example
c3945-mcqueen(config)#license accept end user agreement
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO PRODUCT FEATURE OR USING SUCH
PRODUCT FEATURE CONSTITUTES YOUR FULL ACCEPTANCE OF THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
Use of this product feature requires an additional license from Cisco,
together with an additional payment. You may use this product feature
on an evaluation basis, without payment to Cisco, for 60 days. Your use
of the product, including during the 60 day evaluation period, is
subject to the Cisco end user license agreement
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
If you use the product feature beyond the 60 day evaluation period, you
must submit the appropriate payment to Cisco for the license. After the
60 day evaluation period, your use of the product feature will be
governed solely by the Cisco end user license agreement (link above),
together with any supplements relating to such product feature. The
above applies even if the evaluation license is not automatically
terminated and you do not receive any notice of the expiration of the
evaluation period. It is your responsibility to determine when the
evaluation period is complete and you are required to make payment to
Cisco for your use of the product feature beyond the evaluation period.
Your acceptance of this agreement for the software features on one
product shall be deemed your acceptance with respect to all such
software on all Cisco products you purchase which includes the same
software. (The foregoing notwithstanding, you must purchase a license
for each software feature you use past the 60 days evaluation period,
so that if you enable a software feature on 1000 devices, you must
purchase 1000 licenses for use past the 60 day evaluation period.)
Activation of the software command line interface will be evidence of
your acceptance of this agreement.
ACCEPT? [yes/no]: yes
000436: *Jan 28 17:42:44.625: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User
License Agreement is accepted
c3945-mcqueen#show license detail cme-srst
Feature: cme-srst Period left: 621 weeks 5 days
License Type: Evaluation
Evaluation total period: 208 weeks 2 days
Evaluation period left: 205 weeks 1 day
Expiry date: Jan 04 2015 16:11:17
License Count: 5000/20/0 (Active/In-use/Violation)
Store Index: 23
Store Name: Evaluation License Storage
Index: 2 Feature: cme-srst Version: 1.0
License State: Inactive
Evaluation period left: 208 weeks 2 days
License Count: 5000/0/0 (Active/In-use/Violation)
Store Index: 22
Index: 3 Feature: cme-srst Version: 1.0
Store Index: 21
c3945-mcqueen#
Activating an Evaluation License
Note Starting with Cisco IOS Releases 15.0(1)M6, 15.1(1)T4, 15.1(2)T4, 15.1(3)T2, and 15.1(4)M, Evaluation licenses are replaced with Evaluation Right To Use licenses. Evaluation Right to Use licenses automatically become Right to Use licenses after the initial evaluation period. Follow the steps detailed in this section to activate an Evaluation Right to Use license.
To activate an evaluation license in the Cisco 3900 series, 2900 series, and 1900 series routers, perform the steps detailed in this section. Evaluation licenses are activated using the license boot module module-name technology-package package-name command.
SUMMARY STEPS
1. enable
3. license boot module module-name technology-package package-name
4. exit
5. reload
DETAILED STEPS
Step 1 | enable Example: Router>enable | Enables privileged EXEC mode. •Enter your password if prompted. |
Step 2 | configure terminal Example: Router#configure terminal | Enters global configuration mode. |
Step 3 | license boot modulemodule-nametechnology-packagepackage-name Example: Router(config)#license boot module c3900 technology-package securityk9 | Enables the evaluation license. Use the ? command with the modulecommand to see the module name for your router, and with the technology-packagecommand to see the software packages and features supported on your router. |
Step 4 | exit Example: Router(config)#exit | Exits global configuration mode. |
Step 5 | reload Example: Router#reload | Reloads the router. A reload is required to activate the software package. |
Example
The following example shows how to activate an evaluation license:
Router> enable
Router(config)# license boot module c3900 technology-package data
You hereby acknowledge and agree that the product feature license
is terminable and that the product feature enabled by such license
may be shut down or terminated by Cisco after expiration of the
applicable term of the license (e.g., 30-day trial period). Cisco
reserves the right to terminate or shut down any such product feature
electronically or by any other means available. While alerts or such
messages may be provided, it is your sole responsibility to monitor
your terminable usage of any product feature enabled by the license
and to ensure that your systems and networks are prepared for the shut
down of the product feature. You acknowledge and agree that Cisco will
not have any liability whatsoever for any damages, including, but not
limited to, direct, indirect, special, or consequential damages related
to any product feature being shutdown or terminated. By clicking the
"accept" button or typing "yes" you are indicating you have read and
agree to be bound by all the terms provided herein.
% use 'write' command to make license boot config take effect on next boot
Router(config)#
*Jul 7 00:38:56.391: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900
Next reboot level = securityk9 and License = securityk9
*Jul 7 00:38:56.987: %LICENSE-6-EULA_ACCEPTED: EULA for feature securityk9 1.0 has been
accepted. UDI=C3900-SPE150/K9:FHH12250057; StoreIndex=1:Evaluation License Storage
Router# reload
Router# show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 12.4(24.6)PI11k PI11
ENGINEERING WEEKLY BUILD, synced to V124_24_6_T9
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 15-Jun-09 15:27 by pallavik
ROM: System Bootstrap, Version 15.0(1r)M, RELEASE SOFTWARE (fc1)
Router uptime is 1 day, 3 hours, 53 minutes
System image file is "flash0:c3900-universalk9-mz.SSA.124-24.6.PI11k"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C3945 (revision 1.0) with 2025472K/71680K bytes of memory.
Processor board ID FHH1226P01E
3 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
2 ISDN Basic Rate interfaces
1 ATM interface
25 terminal lines
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
2000880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C3900-SPE150/K9 FHH12250057
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Evaluation securityk9
uc ucK9 Permanent uck9
data None None None
Configuration register is 0x0
Hope this helps
Thanks & Regards,
Venkitesh
03-05-2013 01:39 AM
Hello Banik,
Kindly read this sentence very carefully. Hope you will understand.
Thanks & Regards,
Venkitesh
03-05-2013 01:59 AM
Dear Venkitesh,
Thanks for your feedback. We have already procured CME-SRST license-(225). Do i need to install the same or it will work automaticaly after 60 days?
May i start configuring phone now with EvalRightToUse license ?
Will it work ?
I have to start my IP-PABX Operation and can't wait for 60 more days.
To start configuration, do i need to do any thing extra ?
Di i need to genarate any license key with PAK key from cisco ;icense page ?
03-05-2013 02:06 AM
Hello Banik,
There is no other license other than the paper license which you receive when you get the router.
Yes you can start ahead with the configuration and all the IP Phones will start working. This will continue to work even after the evaluation period is over. No worries.
Just limit the ephones to 225 in telephony-service. Thats it.
Remaining else everything will work perfect. No worries / issues.
Best of luck with your configuration. Any queries / issues with configuration, just make a post and we are there to help you out.
Thanks & Regards,
Venkitesh
03-05-2013 02:12 AM
Hi Banik,
Just to add what Mr. Iyer has said License Type would get changed to RightTOUse after 60 days and is valid for 12 years. You can run the command show license detail cme-srst to check the status after 60 days.
Licenses are honor based and cannot be enforced.
regds,
aman
03-05-2013 02:28 AM
Tjanks a lot
Yes in deed, i have receive papaer license (Fl-CME-SRST-100). After 60 days automaticaly my router will show
License Type: Parmanent
License Count: 240/0 as many license i have purchased
or i have to install license (Fl-CME-SRST-100) later.
Please make me correct.
03-05-2013 02:41 AM
Banik,
Yes what you have written is correct.
The router will show all the licenses are permanent. And the License Count total is 240. And /0 will show how many IP Phones are Registered.
There is no need to install / add any other license.
Hope this helps.
Thanks & Regards,
Venkitesh
03-05-2013 03:09 AM
Thankas a Lot. Let me proceed with configuring the. For any further assistance will knock u up.
It was great help-------------------
03-05-2013 08:42 PM
Dear Venkitesh,
Can you tell me why i am seeing this in to route. Is there any problem ?
BDFCL-CCME#sh ephone reg
BDFCL-CCME#sh ephone registered
No ephone in specified type/condition.
But i have added few phones.
For your ref
BDFCL-CCME##sh license
BDFCL-CCME#show license detail cme-srst
Period used: 20 hours 42 minutes
Transition date: May 04 2013 07:47:00
Store Index: 7
03-05-2013 10:20 PM
Hello Banik,
I have attached a pdf file Cisco Unified Communications Manager Express System Administrator Guide
Hope this helps in configuring the CME and IP Phones.
In case you still face any issue, let us know.
Thanks & Regards,
Venkitesh
