C3945-CME-SRST/K9 problem
sabuz_banik
Dear Concern,
We procure a C3945-CME-SRST/K9 with 2 more FL-CME-SRST-100 license. We have ordered the both in a single order. Now we are seeing this bellow out put in router.
Feature: cme-srst                        Period left: 8  weeks 3  days
Index: 1 Feature: cme-srst                          Version: 1.0
License Type: EvalRightToUse
License State: Active, In Use
    Evaluation total period: 8  weeks 4  days
    Evaluation period left: 8  weeks 3  days
    Period used: 3  minutes 6  seconds
    Transition date: May 04 2013 07:47:01
License Count: 240/0  (In-use/Violation)
License Priority: Low
Store Index: 7
Store Name: Built-In License Storage
License type should be Parmannent with more linecse count.
12 Replies 12
Aman Soi
Hi Banik,
Did you issue license accepy end user agreement command in router ? After u do that License Type :  EvalRightTOUse should change to RightTOUse.
regds,
aman
Dear all,
Yes i have already done your advice process.The bellow out put
Store Index: 7
came after doing bellow process
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
My question is, i have procure CME-SRST bundle which should come with 25 CME-SRT license by default and license type should be parmanent.
Do i need to configure license for my rest license (FL-CME-SRST-100) ?
why it is showing
License Type: EvalRightToUse even after executing license accept end user agreement steps.
Pls advice.
Hello Banik,
Kindly find the details below. This should help you with all your queries / issues with regards to licensing.
Activating CME-SRST Feature License
The ISR G2 comes with a 60-day evaluation license. After 60 days, the license changes to "right to use". The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Note CME-SRST RTU license is introduced in Cisco IOS release 15.1(3)T and higher.
Prerequisites
•UCK9 license
•ISR G2 already accepts UC CLIs
•CME-SRST feature must be configured
SUMMARY STEPS
4. exit
6. write mem
DETAILED STEPS
Command or Action
Purpose
Step 1
Example:
Router# show license   detail cme-srst
Displays the available   cme-srst license. EULA should be in NOT ACCEPTED state.
Step 2
configure terminal
Example:
Router# configure   terminal
Enters global   configuration mode.
Step 3
Example:
Router(config)#   license accept end user agreement
Configures a one-time   acceptance of the EULA for cme-srst license.
Accepts EULA by typing   YES.
Step 4
exit
Example:
Router(config)# exit
Exits global   configuration mode.
Step 5
Example:
Displays the available   cme-srst license. EULA should be in ACCEPTED state.
Step 6
write mem
Example:
Router# write mem
Saves configuration.
Example
c3945-mcqueen(config)#license accept end user agreement
PLEASE  READ THE  FOLLOWING TERMS  CAREFULLY. INSTALLING THE LICENSE OR
LICENSE  KEY  PROVIDED FOR  ANY CISCO  PRODUCT  FEATURE  OR  USING SUCH
PRODUCT  FEATURE  CONSTITUTES  YOUR  FULL ACCEPTANCE  OF  THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO  BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
Use of this product feature requires  an additional license from Cisco,
together with an additional  payment.  You may use this product feature
on an evaluation basis, without payment to Cisco, for 60 days. Your use
of the  product,  including  during the 60 day  evaluation  period,  is
subject to the Cisco end user license agreement
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
If you use the product feature beyond the 60 day evaluation period, you
must submit the appropriate payment to Cisco for the license. After the
60 day  evaluation  period,  your  use of the  product  feature will be
governed  solely by the Cisco  end user license agreement (link above),
together  with any supplements  relating to such product  feature.  The
above  applies  even if the evaluation  license  is  not  automatically
terminated  and you do  not receive any notice of the expiration of the
evaluation  period.  It is your  responsibility  to  determine when the
evaluation  period is complete and you are required to make  payment to
Cisco for your use of the product feature beyond the evaluation period.
Your  acceptance  of  this agreement  for the software  features on one
product  shall be deemed  your  acceptance  with  respect  to all  such
software  on all Cisco  products  you purchase  which includes the same
software.  (The foregoing  notwithstanding, you must purchase a license
for each software  feature you use past the 60 days evaluation  period,
so  that  if you enable a software  feature on  1000  devices, you must
purchase 1000 licenses for use past  the 60 day evaluation period.)
Activation  of the  software command line interface will be evidence of
your acceptance of this agreement.
ACCEPT? [yes/no]: yes
000436: *Jan 28 17:42:44.625: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User
License Agreement is accepted
c3945-mcqueen#show license detail cme-srst
Feature: cme-srst                        Period left: 621 weeks 5  days
        License Type: Evaluation
            Evaluation total period: 208 weeks 2  days
            Evaluation period left: 205 weeks 1  day
            Expiry date: Jan 04 2015 16:11:17
        License Count: 5000/20/0  (Active/In-use/Violation)
        Store Index: 23
        Store Name: Evaluation License Storage
Index: 2        Feature: cme-srst                          Version: 1.0
        License State: Inactive
            Evaluation period left: 208 weeks 2  days
        License Count: 5000/0/0  (Active/In-use/Violation)
        Store Index: 22
Index: 3        Feature: cme-srst                          Version: 1.0
        Store Index: 21
c3945-mcqueen#
Activating an Evaluation License
Note Starting with Cisco IOS Releases 15.0(1)M6, 15.1(1)T4, 15.1(2)T4, 15.1(3)T2, and 15.1(4)M, Evaluation licenses are replaced with Evaluation Right To Use licenses. Evaluation Right to Use licenses automatically become Right to Use licenses after the initial evaluation period. Follow the steps detailed in this section to activate an Evaluation Right to Use license.
To activate an evaluation license in the Cisco 3900 series, 2900 series, and 1900 series routers, perform the steps detailed in this section. Evaluation licenses are activated using the license boot module module-name technology-package package-name command.
SUMMARY STEPS
1. enable
3. license boot module module-name technology-package package-name
4. exit
5. reload
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router>enable
Enables privileged   EXEC mode.
•Enter   your password if prompted.
Step 2
configure terminal
Example:
Router#configure   terminal
Step 3
license boot modulemodule-nametechnology-packagepackage-name
Example:
Router(config)#license   boot module c3900 technology-package securityk9
Enables the evaluation   license.
Use the ? command   with the modulecommand to see the module name for your router,   and with the technology-packagecommand to see the software   packages and features supported on your router.
Step 4
exit
Example:
Router(config)#exit
Step 5
reload
Example:
Router#reload
Reloads the router. A   reload is required to activate the software package.
Example
The following example shows how to activate an evaluation license:
Router> enable
Router(config)# license boot module c3900 technology-package data
You hereby  acknowledge  and  agree that  the  product feature  license
is terminable and that the product  feature  enabled  by  such  license
may  be  shut  down or  terminated by  Cisco  after  expiration of  the
applicable  term  of  the license  (e.g., 30-day  trial  period). Cisco
reserves the  right to terminate or shut down  any such product feature
electronically  or by  any other  means available. While alerts or such
messages  may  be provided, it is  your sole  responsibility to monitor
your terminable  usage of any  product  feature enabled by  the license
and to ensure that your systems and  networks are prepared for the shut
down of the product feature. You acknowledge  and agree that Cisco will
not have any liability  whatsoever for  any damages, including, but not
limited to, direct, indirect, special, or consequential damages related
to any product  feature  being shutdown or terminated. By clicking  the
"accept" button  or typing "yes" you are  indicating  you have read and
agree to be bound by all the terms provided herein.
% use 'write' command to make license boot config take effect on next boot
Router(config)#
*Jul  7 00:38:56.391: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3900
Next reboot level = securityk9 and License = securityk9
*Jul  7 00:38:56.987: %LICENSE-6-EULA_ACCEPTED: EULA for feature securityk9 1.0 has been
accepted. UDI=C3900-SPE150/K9:FHH12250057; StoreIndex=1:Evaluation License Storage
Router# reload
Router# show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 12.4(24.6)PI11k PI11
ENGINEERING WEEKLY BUILD, synced to V124_24_6_T9
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 15-Jun-09 15:27 by pallavik
ROM: System Bootstrap, Version 15.0(1r)M, RELEASE SOFTWARE (fc1)
Router uptime is 1 day, 3 hours, 53 minutes
System image file is "flash0:c3900-universalk9-mz.SSA.124-24.6.PI11k"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C3945 (revision 1.0) with 2025472K/71680K bytes of memory.
Processor board ID FHH1226P01E
3 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
2 ISDN Basic Rate interfaces
1 ATM interface
25 terminal lines
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
2000880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       FHH12250057
Technology Package License Information for Module:'c3900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Evaluation    securityk9
uc            ucK9          Permanent     uck9
data          None          None          None
Configuration register is 0x0
Hope this helps
Thanks & Regards,
Venkitesh
Hello Banik,
Kindly read this sentence very carefully. Hope you will understand.
Thanks & Regards,
Venkitesh
Dear Venkitesh,
Thanks for your feedback. We have already procured CME-SRST license-(225). Do i need to install the same or it will work automaticaly after 60 days?
May i start configuring phone now with EvalRightToUse license ?
Will it work ?
I have to start my IP-PABX Operation and can't wait for 60 more days.
To start configuration, do i need to do any thing extra ?
Di i need to genarate any license key with PAK key from cisco ;icense page ?
Hello Banik,
There is no other license other than the paper license which you receive when you get the router.
Yes you can start ahead with the configuration and all the IP Phones will start working. This will continue to work even after the evaluation period is over. No worries.
Just limit the ephones to 225 in telephony-service. Thats it.
Remaining else everything will work perfect. No worries / issues.
Best of luck with your configuration. Any queries / issues with configuration, just make a post and we are there to help you out.
Thanks & Regards,
Venkitesh
Hi Banik,
Just to add what Mr. Iyer has said  License Type would get changed to RightTOUse after 60 days and is valid for 12 years. You can run the command show license detail cme-srst to check the status after 60 days.
Licenses are honor based and cannot be enforced.
regds,
aman
Tjanks a lot
Yes in deed, i have receive papaer license (Fl-CME-SRST-100). After 60 days automaticaly my router will show
License Type: Parmanent
License Count: 240/0  as many license i have purchased
or i have to install license (Fl-CME-SRST-100) later.
Please make me correct.
Banik,
Yes what you have written is correct.
The router will show all the licenses are permanent. And the License Count total is 240. And /0 will show how many IP Phones are Registered.
There is no need to install / add any other license.
Hope this helps.
Thanks & Regards,
Venkitesh
Thankas a Lot. Let me proceed with configuring the. For any further assistance will knock u up.
It was great help-------------------
Dear Venkitesh,
Can you tell me why i am seeing this in to route. Is there any problem ?
BDFCL-CCME#sh  ephone reg
BDFCL-CCME#sh  ephone registered
No  ephone in specified type/condition.
But i have added few phones.
For your ref
BDFCL-CCME##sh  license
BDFCL-CCME#show  license detail cme-srst
             Period used: 20 hours 42 minutes
             Transition date: May 04 2013 07:47:00
         Store Index: 7
Hello Banik,
I have attached a pdf file Cisco Unified Communications Manager Express System Administrator Guide
Hope this helps in configuring the CME and IP Phones.
In case you still face any issue, let us know.
Thanks & Regards,
Venkitesh
