05-31-2013 09:53 AM - edited 03-16-2019 05:38 PM
Does anyone know if C892F-CUBE-K9 supports CME? I can't even locate any specs on this router. Does it have DSPs?
The Feature Navigator states that it supports CME (up to 8.6). However, it may need the SL-8XX-UC-K9 license to activate the CME-SRST features. I can't find any informatoin on this. I would also like to know if it can run CME, how many IP phones on CME it supports.
I'm trying to decide between C881-V-K9 and C892-F-CUBE-K9.
C881-V-K9 runs CME and supports 5 phones but requres the SL-8XX-UC-K9 license for CME.
Thanks.
05-31-2013 11:10 AM
Also, I forgot to mention that optimally, I would like to have the CUBE, CME, and SRST features in the router so that I could use it not only for my home telephony but also for my home voice lab.
It appears that C881-V-K9 would give me CME and SRST (with the SL-8XX-UC-K9 software license), but it does not have the CUBE feature in it (if I can trust the Feature Navigator). On the other hand, the C892F-CUBE-K9 comes with the CUBE license, and it supposedly supports CME (per Feature Navigator), but because I can't find any information on this router anywhere, it's unclear if I coiuld purchase the SL--8XX-UC-K9 license and activate CME/SRST features in it.
I really need more than 5 phones to be supported; eight phones would be optimal. So, I'm hoping that C892F-CUBE-K9 can run CME and supports 8 phones. Wishful thinking?
The reason I'm looking for a new router for CME is because the final CME version supported on the 28XX/38XX Series routers is 8.6. These first generation ISR routers can't run anything above 8.6. I need to pick up a few Cisco 8945 phones, but they are not supported in 8.6. The earliest version they are supported as SCCP phones is 8.8, and they are supported in 9.0 and above as both SCCP and SIP. So, it appeas my 2801 that I've been using for 7 years as a CME router has arrived at the retirement age.
Unfortunately, the next step up from C881-V-K9 is 1861E (which supports CME 8.8, 9.0, and 9.1), but it's much more expensive than 881-V, and I'm not prepared to pay that much for a router that only has marginal improvements over my 2801.
So, I'm keeping my fingers crossed for C892F-CUBE-K9. Please help me with the information if you have it.
Thank you!
08-17-2013 09:34 AM
I have Cisco 892W at home. It is great router with quiet fan, and powerfull with 8 ports switch built in.
I have advipservices and latest IOS showing CME at version 9.5. I will try to register Cisco 9971, but have not done it yet so far...
BER-UK#sh ver
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 28-Mar-13 14:27 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
BER-UK uptime is 3 weeks, 1 day, 15 hours, 53 minutes
System returned to ROM by reload at 01:35:47 GMT Fri Jul 26 2013
System restarted at 01:36:38 GMT Fri Jul 26 2013
System image file is "flash:c890-universalk9-mz.153-2.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 892 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FHK144571AA
9 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ISDN Basic Rate interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO892W-AGN-E-K9 FHK144571AA
License Information for 'c890'
License Level: advipservices Type: Permanent
Next reboot license Level: advipservices
BER-UK#sh voice register globa
BER-UK#sh voice register global ?
| Output modifiers
CONFIG [Version=9.5]
Version 9.5
Mode is cme
Max-pool is 5
Max-dn is 10
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 10.10.32.254 port 5060
Load 9971 is sip9971.9-3-4-24
Time-format is 24
Date-format is D/M/Y
Time-zone is 21
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Dialplan 1 ... extension-length 3
Forwarding local is enabled
Video is disabled
Camera is disabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is enabled
Tftp files are created, current syncinfo 0001501064732097
OS79XX.TXT is not created
timeout interdigit 10
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 0
Total SIP phones registered: 0
Total Registration Statistics
Registration requests : 2
Registration success : 0
Registration failed : 2
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Attempts to register
after last unregister : 2
Last register request time : 16:07:08.298 GMT Fri Jul 26 2013
Last unregister request time :
Register success time :
Unregister success time :
BER-UK#
08-17-2013 01:03 PM
Please post the results of trying to register a phone with CME on the 892 router.
I ended up buying an 881-v router. The SL license that I was referring to in my original post is a paper PAK that Cisco charges $350 list price for. The CME-SRST feature is part of Advanced IP Services IOS image, and the UC software license is not enforceable on the 881-v router. UCK9 technology package is enforceable on the ISR G2 platform.
So, make your conclusion about buying the SL license if you are going to use this router at home.
On 881-v, when I issue "show run" (or "show license"), I don't see any license listed similar to ISR G1 routers.
I would be very interested in seeing if the 892 router can run CME. Also, could you change to the telephony-service mode. And see how many max-ephones and max-dn it supports? 881-v supports 5 ephones and 50 DNs.
Could you post the output of the show license command?
