10-05-2011 06:10 AM - edited 03-16-2019 07:20 AM
I currently have a router with the following modules
NM-HDV2-2T1/E1 with VWIC2 2MFT T1/E1 and a separate VWIC3-2MFT T1/E1
All to be used as E1 so giving 6x E1 ports in a 3945 IOS 15.X router. The router will only be used for E1 no conf or transcoding. I looked at the DSP Calculator and it suggested I do not need any DSP`s - Is this correct ?
I just need a second opinion on this - If we do not do any conf or transcoding it seems no DSP are required? - Is this right
thanks
10-07-2011 06:49 AM
You seem to have 3 versions of this post
I have answered - Yes if you are using voice then you REQUIRE dsp resources.
Alex
10-07-2011 07:13 AM
Hi IPT,
I only factored in the VWIC2 2MFT T1/E1 & VWIC3-2MFT T1/E1 and
here are the results from the DSP calculator
Video Conferencing and Transcoding
| Router: 3945 |
| IOS: 15.1(2)T |
| DSP Modules Required: | |
| PVDM3-128: 1 | |
| DSP Module Allocation: | |||||
| Router Slot 0: | 120 Voice (94%) 8 Available (6%) | ||||
| PVDM Slot 0/0: PVDM3-128 | |||||
| Router Slot 1: | |||||
| Router Slot 2: | |||||
| Router Slot 3: | |||||
| Router Slot 4: | |||||
| Call Volume Allocation: | |||||
| Router Slot 0 | Low | Med | High | ||
| Slot 0/0: VWIC3-2MFT-T1/E1(E1) | 60 | ||||
| Slot 0/1: VWIC2-2MFT-T1/E1(E1) | 60 | ||||
Video Conferencing and Transcoding:
Cheers!
Rob
10-07-2011 08:21 AM
thanks rob - seen my mistake forgot to put in the number of channels - saw the system entered in 60 but that was only potential
