Calendar icon on jabber client
MayurSadhu1089
Jabber user getting below pop-up twice when log in to jabber client. after first pop-up calendar icon gets display on client and after second pop-up it disappears.
b.winter
Probably because after the installation and / or reset of Jabber, Jabber displays the icon per default --> then Jabber gets a new config file from CUCM and updates its config.
In the config file, the Calender service is deactivated and therefore Jabber doesn't display it anymore.
If the config file is configured like that, then it "works as designed". So, this is not a problem.
b.winter
b.winter
@MayurSadhu1089 Any update here or just another dead post?
