Hi, we are having expressway dual nic setup. in expressway e ip configuration i changed ipv4 gateway and given LAN2 Default gateway. like the below snap now web interface is not coming and please suggest how can i revert the configuration throug...
Hello! We have a problem with transfers in cisco. We use a Cisco UCM and have SIP numbers there.Need to make a transfer function, but if we have an external number, we get a 404 error.Steps:User A (SIP) has a call with User B (any mobile number)User ...
hi please, tag 200 is in busyout, which CLI command to reset the TAG 200? GNEGNEO#sh dial- voice sumdial-peer hunt 0AD PRE PASS SESS-SER-GRP\ OUTTAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF100 voip up up 0 sys...
Hello Everyone, I am currently having an issue with regards to changing the time on our CME. I do the following, get into the voice register global, set the timezone to 17, then 'create profile'. then i get the following errors. %Error deleting flash...
Hello,I want to monitor Available Members from Hunt List. I go to in RTMT to Performance-Hunt Lists-MembersAvailable but I always get 0, even if there are agents that are loged in.Does someone know, how to resolve this?
I have several users receiving Error Loading Report when logging to Finesse. They are using Jabber, no desk phones.CUCM 12.5, Jabber 14.1, Edge browser. We tried Chrome and had the same issue. These users were all configured at the same time. Most ha...
Hi All, I'd like to ask your valuable help for the following question: - is there a way to change the MTU size of the CUCM endpoints (Dx650, 7841, etc...) packets ? Customer indeed has an environment in which some recently added crypto device ask...
Hello everyone, I'm a newbie and just started my CS career about 2/3weeks ago, i've been self learning and i just get done with Network basics on Cisco Network. My quesdtion is, what should i do next? since i have no mentor , is this the stage where...
my CUCM is up but not reachable even while is up it still not sending packetMy CUCM is not pingable even while is actively up, how can i solve this kind of problem
Hello,We are having an issue with one of our locations. When an inbound call comes in, sometimes the call will continue to ring into the handset after the call is "answered" with the handset. Then our user can hang up the handset, the display will ch...
Hi,When inbound call came from Sip trunk and the extension 201 answer the call and try transfer to another extension never works.Could you help me?Follow show run attached.Detail , i dont know why but aparently when user press button transfer and di...
Hi AllI upgraded CUCM from 12.5 to 14. After that, the existing licenses were no longer valid. For example i have 200 UC Manager Basic License (12.x) but 0 UC Manager Basic LicenseWhat should I do next? Does Cisco have to convert one (12.5) to the ot...
Hi guys, I have a trunk from my CUCM to an Avaya, the SIP trunk was working fine, but suddenly the following error appeared, remote = 503, If I arrive by ICMP to the IP of the Avaya, I have restarted the SIP Trunk and the behavior is the same. Th...
Call Manager Version: 6.0.1.2113-1BAT only appears to only import 16 user records at a time, I open the CSV delete the first 15 rows and then import again and it works.Always get error USERID (Record Number 16) 2003 Record does not match the selected...
We have upgraded from 3.8 to 3.9.When trying to use the Smart licensing it is not connecting I found that there is a bugg of some kind that makes Prime 3.9 not connecting.How to use the traditional licensing when my licensing account looks like this:...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
