06-28-2013 01:36 AM - edited 03-16-2019 06:07 PM
Dear All ,
I have one Voice Gateway cisco 2911 and CUCM 8.6 . I want to block all incoming Call from outside to EXT :111 and make this EXTs available just internal or inside the CLUSTER.I tried to use translation pattern on the CUCM . But, its not work
kindly help me out for this problem?
Solved! Go to Solution.
06-28-2013 01:38 AM
place that extension into a partition which is not visible for the CSS set on the gateway.
Include this partition in a CSS on the phones connected to the cluster.
G.
06-28-2013 01:38 AM
G.
06-28-2013 03:10 AM
Thanks Gerqely....
