call cannot be completed at this time... please try again later
voipeee
Level 3
Level 3
Hi Guys,
One of number's I call is saying your call can't be completed and afterward the call will disconnect. I collected the logs on gateways and it is showing normal call clearing. For privacy reasons I replaced last 6 digits of calling and called number with 6(xxxxxx) and 6(yyyyyy) respectively. All other similar patterns are working fine.
Call flow CUCM > SIP Trunk to SP.
Here are the Gateway logs:
From: <sip:9045xxxxxx@10.221.1.173>;tag=BEC912E9-996
To: <sip:9042yyyyyy@10.221.1.173>;tag=525587411-1519676286142
Call-ID: FCF6E2DF-1A6811E8-967BC22A-E49D705C@10.221.69.58
CSeq: 101 INVITE
Timestamp: 1519676285
Supported: timer
Contact: <sip:10.221.1.173:5060;transport=udp>
Call-Info: <sip:12.95.84.143>;appearance-index=1
Allow: INVITE,ACK,CANCEL,BYE,REFER,INFO,NOTIFY,PRACK,OPTIONS
Server: Cisco-CUCM10.5
Content-Length: 0
1888679: Feb 26 15:18:06.227: //6242021/25B242000000/CCAPI/cc_api_call_alert:
Interface=0x7F2612BAC260, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
1888680: Feb 26 15:18:06.227: //6242021/25B242000000/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
1888681: Feb 26 15:18:06.227: //6242020/25B242000000/CCAPI/ccCallAlert:
1888682: Feb 26 15:18:06.227: //6242020/25B242000000/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
1888683: Feb 26 15:18:06.227: //6242020/25B242000000/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=6242020
1888684: Feb 26 15:18:06.228: //6242020/25B242000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/TCP 172.20.160.12:5060;branch=z9hG4bKc73c168a16b
From: <sip:9045xxxxxx@172.20.160.12>;tag=5563822~77fad1d8-6360-4e54-adc6-de459223602b-41061407
To: <sip:9042yyyyyy@172.20.160.3>;tag=BEC914AC-239F
Date: Mon, 26 Feb 2018 15:18:05 GMT
Call-ID: 25b24200-a9416b7d-b3a2b-ca014ac@172.20.160.12
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
P-Asserted-Identity: <sip:9042yyyyyy@172.20.160.3>
Contact: <sip:9042yyyyyy@172.20.160.3:5060;transport=tcp>
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
1888685: Feb 26 15:18:06.351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.20.160.3:5060 SIP/2.0
Via: SIP/2.0/TCP 172.20.160.12:5060;branch=z9hG4bKc73c24031b19a
To: <sip:172.20.160.3>
Date: Mon, 26 Feb 2018 20:18:06 GMT
Call-ID: 264ad880-a9416b7e-b3a2c-ca014ac@172.20.160.12
User-Agent: Cisco-CUCM11.5
CSeq: 101 OPTIONS
Contact: <sip:172.20.160.12:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
1888686: Feb 26 15:18:06.353: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.20.160.3>;tag=BEC91528-958
Date: Mon, 26 Feb 2018 15:18:06 GMT
CSeq: 101 OPTIONS
Accept: application/sdp
Supported: timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 1585 5240 IN IP4 172.20.160.3
s=SIP Call
c=IN IP4 172.20.160.3
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
1888687: Feb 26 15:18:06.361: //6242021/25B242000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 10.221.69.58:5060;branch=z9hG4bK5589AA55B
CSeq: 101 INVITE
Supported: timer
Allow: INVITE,ACK,CANCEL,BYE,REFER,INFO,NOTIFY,PRACK,UPDATE,OPTIONS
Content-Length: 0
1888688: Feb 26 15:18:06.386: //6242021/25B242000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Session-Expires: 1800;refresher=uas
Supported: timer
Accept: application/dtmf-relay, application/media_control+xml, application/sdp
Content-Length: 251
v=0
o=BroadWorks 954633586 1 IN IP4 10.221.1.173
s=-
c=IN IP4 10.221.1.173
t=0 0
m=audio 48164 RTP/AVP 18 0 8 101
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
1888689: Feb 26 15:18:06.387: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888690: Feb 26 15:18:06.387: cc_api_get_xcode_stream : 4983
1888691: Feb 26 15:18:06.387: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888692: Feb 26 15:18:06.387: cc_api_get_xcode_stream : 4983
1888693: Feb 26 15:18:06.387: //6242021/25B242000000/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6242021,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
1888694: Feb 26 15:18:06.387: //6242021/25B242000000/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
1888695: Feb 26 15:18:06.387: //6242020/25B242000000/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6242020,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5316)
1888696: Feb 26 15:18:06.387: //6242020/25B242000000/CCAPI/cc_api_caps_ack:
1888697: Feb 26 15:18:06.387: //6242021/25B242000000/CCAPI/cc_api_event_indication:
Event=101, Call Id=6242021
1888698: Feb 26 15:18:06.387: //6242021/25B242000000/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
1888699: Feb 26 15:18:06.387: //6242021/25B242000000/CCAPI/cc_api_call_connected:
Interface=0x7F2612BAC260, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
1888700: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
1888701: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888702: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
1888703: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888704: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
1888705: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
1888706: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
1888707: Feb 26 15:18:06.388: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6242021
1888708: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888709: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
1888710: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888711: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
1888712: Feb 26 15:18:06.388: //6242020/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
1888713: Feb 26 15:18:06.388: //6242021/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
1888714: Feb 26 15:18:06.388: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6242020
1888715: Feb 26 15:18:06.388: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
Call Id 6242021
1888716: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x5F3EE4, gcid=FCF646B7-1A6811E8-9678C22A-E49D705C, tag=0x0)
1888717: Feb 26 15:18:06.389: //6242021/25B242000000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x5F3EE5, gcid=FCF646B7-1A6811E8-9678C22A-E49D705C, tag=0x0)
1888718: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=6242020, Call Id2=6242021, Tag=0x0
1888719: Feb 26 15:18:06.389: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888720: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888721: Feb 26 15:18:06.389: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888722: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888723: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccConferenceCreate:
1888724: Feb 26 15:18:06.389: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=0, dtmf1=6
ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
1888725: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888726: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
1888727: Feb 26 15:18:06.389: //6242021/25B242000000/CCAPI/ccGetMediaClassTag:
media class tag 0
1888728: Feb 26 15:18:06.389: //6242021/25B242000000/CCAPI/ccSetMediaclassIp2ipTags:
1888729: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
1888730: Feb 26 15:18:06.389: //6242021/25B242000000/CCAPI/ccGet_xc_nr_asp_info:
1888731: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/ccConferenceCreate:
delay media to slow start case, codec negotation is not done
1888732: Feb 26 15:18:06.389: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888733: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888734: Feb 26 15:18:06.389: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888735: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888736: Feb 26 15:18:06.389: //6242020/25B242000000/CCAPI/cc_api_bridge_done:
Conference Id=0xC18F, Source Interface=0x7F2612BAC260, Source Call Id=6242020,
Destination Call Id=6242021, Disposition=0x0, Tag=0x0
1888737: Feb 26 15:18:06.389: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888738: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888739: Feb 26 15:18:06.389: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888740: Feb 26 15:18:06.389: cc_api_get_xcode_stream : 4983
1888741: Feb 26 15:18:06.390: //6242021/25B242000000/CCAPI/cc_api_bridge_done:
Conference Id=0xC18F, Source Interface=0x7F2612BAC260, Source Call Id=6242021,
Destination Call Id=6242020, Disposition=0x0, Tag=0x0
1888742: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/cc_generic_bridge_done:
1888743: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xC18F, Destination Call Id=6242021)
1888744: Feb 26 15:18:06.390: //6242021/25B242000000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xC18F, Destination Call Id=6242020)
1888745: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/ccConferenceCreate:
1888746: Feb 26 15:18:06.390: confID:0xC18F; callEntry1 callID1:0x5F3EE4, type:3; callEntry2 callID2:0x5F3EE5, type:3
1888747: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xC18F, Call Id1=6242020, Call Id2=6242021
1888748: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
1888749: Feb 26 15:18:06.390: //6242020/25B242000000/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
1888750: Feb 26 15:18:06.392: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888751: Feb 26 15:18:06.392: cc_api_get_xcode_stream : 4983
1888752: Feb 26 15:18:06.392: //6242020/25B242000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 2160 8980 IN IP4 172.20.160.3
s=SIP Call
t=0 0
m=audio 42600 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
1888753: Feb 26 15:18:06.407: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:9042yyyyyy@172.20.160.3:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.20.160.12:5060;branch=z9hG4bKc73c322b573d7
Date: Mon, 26 Feb 2018 20:18:05 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: presence, kpml
Session-ID: 97e44c6786537f0c0dda24fb7e654ba0;remote=1b2f3479b0db2a5aa6f4d75ab5563822
Content-Length: 249
v=0
o=CiscoSystemsCCM-SIP 5563822 1 IN IP4 172.20.160.12
s=SIP Call
c=IN IP4 172.19.10.189
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 24596 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
1888754: Feb 26 15:18:06.408: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888755: Feb 26 15:18:06.408: cc_api_get_xcode_stream : 4983
1888756: Feb 26 15:18:06.408: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888757: Feb 26 15:18:06.408: cc_api_get_xcode_stream : 4983
1888758: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888759: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888760: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888761: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888762: Feb 26 15:18:06.409: //6242020/25B242000000/CCAPI/cc_api_caps_ind:
Destination Interface=0x7F2612BAC260, Destination Call Id=6242021, Source Call Id=6242020,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
1888763: Feb 26 15:18:06.409: //6242020/25B242000000/CCAPI/cc_api_caps_ind:
1888764: Feb 26 15:18:06.409: //6242021/25B242000000/CCAPI/cc_api_caps_ack:
Destination Interface=0x7F2612BAC260, Destination Call Id=6242020, Source Call Id=6242021,
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=4217)
1888765: Feb 26 15:18:06.409: //6242021/25B242000000/CCAPI/cc_api_caps_ack:
1888766: Feb 26 15:18:06.409: //6242020/25B242000000/CCAPI/cc_api_event_indication:
Event=103, Call Id=6242020
1888767: Feb 26 15:18:06.409: //6242020/25B242000000/CCAPI/cc_api_event_indication:
1888768: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888769: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888770: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888771: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888772: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888773: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888774: Feb 26 15:18:06.409: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888775: Feb 26 15:18:06.409: cc_api_get_xcode_stream : 4983
1888776: Feb 26 15:18:06.410: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
1888777: Feb 26 15:18:06.410: call_info mainst_callID:0x5F3EE4, peer_callID:0x5F3EE5, confID:0xC18F, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
1888778: Feb 26 15:18:06.410: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
1888779: Feb 26 15:18:06.410: stream[0]: callid:0x5F3EE4, media_passthrough:1
1888780: Feb 26 15:18:06.410: //6242020/25B242000000/CCAPI/cc_api_event_indication:
Event=111, Call Id=6242020
1888781: Feb 26 15:18:06.410: //6242020/25B242000000/CCAPI/cc_api_event_indication:
1888782: Feb 26 15:18:06.410: //6242020/25B242000000/CCAPI/cc_api_event_indication:
Event=213, Call Id=6242020
1888783: Feb 26 15:18:06.410: //6242020/25B242000000/CCAPI/cc_api_event_indication:
1888784: Feb 26 15:18:06.410: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888785: Feb 26 15:18:06.410: cc_api_get_xcode_stream : 4983
1888786: Feb 26 15:18:06.410: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888787: Feb 26 15:18:06.410: cc_api_get_xcode_stream : 4983
1888788: Feb 26 15:18:06.410: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888789: Feb 26 15:18:06.410: cc_api_get_xcode_stream : 4983
1888790: Feb 26 15:18:06.410: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888791: Feb 26 15:18:06.410: cc_api_get_xcode_stream : 4983
1888792: Feb 26 15:18:06.410: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888793: Feb 26 15:18:06.410: cc_api_get_xcode_stream : 4983
1888794: Feb 26 15:18:06.410: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888795: Feb 26 15:18:06.411: cc_api_get_xcode_stream : 4983
1888796: Feb 26 15:18:06.411: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888797: Feb 26 15:18:06.411: cc_api_get_xcode_stream : 4983
1888798: Feb 26 15:18:06.411: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888799: Feb 26 15:18:06.411: cc_api_get_xcode_stream : 4983
1888800: Feb 26 15:18:06.411: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
1888801: Feb 26 15:18:06.411: call_info mainst_callID:0x5F3EE5, peer_callID:0x5F3EE4, confID:0xC18F, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
1888802: Feb 26 15:18:06.412: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
1888803: Feb 26 15:18:06.412: stream[0]: callid:0x5F3EE5, media_passthrough:1
1888804: Feb 26 15:18:06.412: //6242021/25B242000000/CCAPI/cc_api_event_indication:
Event=111, Call Id=6242021
1888805: Feb 26 15:18:06.412: //6242021/25B242000000/CCAPI/cc_api_event_indication:
1888806: Feb 26 15:18:06.412: //6242021/25B242000000/CCAPI/cc_api_event_indication:
Event=213, Call Id=6242021
1888807: Feb 26 15:18:06.412: //6242021/25B242000000/CCAPI/cc_api_event_indication:
1888808: Feb 26 15:18:06.412: //6242021/25B242000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:10.221.1.173:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.221.69.58:5060;branch=z9hG4bK5589ABFEC
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 1955 8735 IN IP4 10.221.69.58
s=SIP Call
c=IN IP4 10.221.69.58
t=0 0
m=audio 43358 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
1888809: Feb 26 15:18:20.177: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:9042yyyyyy@172.20.160.3:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.20.160.12:5060;branch=z9hG4bKc73c416a15160
Max-Forwards: 70
P-Asserted-Identity: <sip:9045xxxxxx@172.20.160.12>
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
1888810: Feb 26 15:18:20.177: //6242021/25B242000000/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=6242021
1888811: Feb 26 15:18:20.177: //6242020/25B242000000/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7F2612BAC260, Call Id=6242020
1888812: Feb 26 15:18:20.177: //6242020/25B242000000/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
1888813: Feb 26 15:18:20.177: //6242020/25B242000000/CCAPI/ccConferenceDestroy:
Conference Id=0xC18F, Tag=0x0
1888814: Feb 26 15:18:20.177: //6242020/25B242000000/CCAPI/ccConferenceDestroy:
1888815: Feb 26 15:18:20.177: confID:0xC18F; callEntry1 callID1:0x5F3EE4, type:3; callEntry2 callID2:0x5F3EE5, type:3
1888816: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888817: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888818: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888819: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888820: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888821: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888822: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888823: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888824: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888825: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888826: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888827: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888828: Feb 26 15:18:20.178: //6242020/25B242000000/CCAPI/cc_api_bridge_drop_done:
1888829: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888830: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888831: Feb 26 15:18:20.178: //6242020/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888832: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888833: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888834: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888835: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888836: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888837: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888838: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888839: Feb 26 15:18:20.178: //6242021/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1888840: Feb 26 15:18:20.178: cc_api_get_xcode_stream : 4983
1888841: Feb 26 15:18:20.178: //6242021/25B242000000/CCAPI/cc_api_bridge_drop_done:
1888842: Feb 26 15:18:20.178: //6242020/25B242000000/CCAPI/cc_generic_bridge_done:
1888843: Feb 26 15:18:20.179: //6242020/25B242000000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
1888844: Feb 26 15:18:20.179: //6242020/25B242000000/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
1888845: Feb 26 15:18:20.179: //6242021/25B242000000/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
1888846: Feb 26 15:18:20.179: //6242021/25B242000000/CCAPI/ccCallDisconnect:
1888847: Feb 26 15:18:20.180: //6242020/25B242000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 26 Feb 2018 15:18:20 GMT
CSeq: 102 BYE
Content-Length: 0
1888848: Feb 26 15:18:20.180: //6242021/25B242000000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:10.221.1.173:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.221.69.58:5060;branch=z9hG4bK5589BBF87
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Timestamp: 1519676300
CSeq: 102 BYE
Max-Forwards: 70
Content-Length: 0
1888849: Feb 26 15:18:20.181: //6242020/25B242000000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F2612BAC260, Tag=0x0, Call Id=6242020,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
1888850: Feb 26 15:18:20.181: //6242020/25B242000000/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
1888851: Feb 26 15:18:20.181: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1888852: Feb 26 15:18:20.181: :cc_free_feature_vsa freeing 7F2614124B40
1888853: Feb 26 15:18:20.181: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1888854: Feb 26 15:18:20.181: vsacount in free is 3
1888855: Feb 26 15:18:20.226: //6242021/25B242000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
1888856: Feb 26 15:18:20.226: //6242021/25B242000000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F2612BAC260, Tag=0x0, Call Id=6242021,
1888857: Feb 26 15:18:20.226: //6242021/25B242000000/CCAPI/cc_api_call_disconnect_done:
1888858: Feb 26 15:18:20.226: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1888859: Feb 26 15:18:20.226: :cc_free_feature_vsa freeing 7F2614124600
1888860: Feb 26 15:18:20.226: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1888861: Feb 26 15:18:20.226: vsacount in free is 2
1888862: Feb 26 15:18:25.562: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.221.69.58:5060 SIP/2.0
Via: SIP/2.0/UDP 10.221.1.173:5060;branch=z9hG4bK83n3mb30c0u1li3um5i1
Call-ID: 9b6b4fd48153f76b95259681f640209d0006pt2@10.221.1.173
To: sip:ping@10.221.69.58:5060
From: <sip:ping@10.221.1.173:5060>;tag=4e4ad5833cc26b1c68924268a9aa1e1d0006pt2
Max-Forwards: 0
CSeq: 37819 OPTIONS
1888863: Feb 26 15:18:25.563: //6242038/08C1FE59968C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@10.221.69.58:5060;tag=BEC96033-1724
Date: Mon, 26 Feb 2018 15:18:25 GMT
CSeq: 37819 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 7391 9992 IN IP4 10.221.69.58
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
1888864: Feb 26 15:18:31.046: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.20.160.11:5060;branch=z9hG4bK1248c25bc32692
Date: Mon, 26 Feb 2018 20:18:31 GMT
Call-ID: 35318b00-a9416b97-9ddfa-ba014ac@172.20.160.11
CSeq: 101 OPTIONS
Contact: <sip:172.20.160.11:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
1888865: Feb 26 15:18:31.049: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.20.160.3>;tag=BEC9759F-A33
Date: Mon, 26 Feb 2018 15:18:31 GMT
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 6704 5610 IN IP4 172.20.160.3
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
GCS-ISR4331#
Dennis Mink
the party that is sending the bye:
Received:
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
is that your cucm?
in which case you might want to do a trace to see why it is disconnecting
Please remember to rate useful posts, by clicking on the stars below.
Hi @Dennis Mink,
Thanks for your help.
The calling number is 9045xxxxxx called number is 9042yyyyyy. 172.20.160.12 is Communications manager Subscriber. I am so concerned why there is no dial-peer in the traces.
Muk
OK, so your called number 9042yyyyyy
when you check the cucm route plan report, does that number exist at all?
can you rting it internally from a phone on the SAME partition and CSS?
cheers
Hi @Dennis Mink,
Thanks for your help!
9042yyyyyy is external number. Yes, there is Route pattern for this which points to the SIP Trunk and on the gateway there is dial-peer to Service provider.
Also if I dial same pattern number for example 9042zzzzzz that uses the same pattern and works fine.
Muk
