Call Disconnect after 30 mins. CUCM Q.850 Cause=41
pematthe
All,  I have tried searching but no-one seems to have a definitive answer.
I have scenarios where calls to the PSTN via a SIP provider are cleared after 30minutes duration everytime.  I have done various diagnostics and narrowed it down to the CUCM sending a SIP BYE to the endpoint and to the CUBE / SIP provider.  Debug on the CUBE shows:
Received:
BYE sip:callmanager@172.27.199.1:5060;transport=tcp SIP/2.0
"output truncated"
CSeq: 102 BYE
Reason: Q.850;cause=41
Content-Length: 0
Cause 41 being "temporary failure"
The path is fine between CUBE and CUCM (same subnet), the internal ip-phone / jabber client receives "Call Preservation" mode and the call is killed.
A packet capture between the ip-phone and CUCM shows "BYE" initiated from CUCM.  We don't see any glitch in the data path there either. Other posts relating to call preservation mode refer to a disconnect in the network path between CUCM and phone unit.  I doubt this is the case, internal calls stay up all the time.
FYI - BE6000S
CUCM 11.0.1.20000-2
CUBE CISCO2921/K9  v15.5(3)M
11 Replies 11
R0g22
What is the session timer set to and who is the session refresher ? The logs should tell you that and you should be able to figure out who is messing up the dialog. If you can share the complete logs, I can look at them.
I have timed it and it is 29 mins and 30 seconds exactly when the call drops, every time.
In CUCM, >> System >> Service Parameters >>SIP the min-SE value is 1800 and the SIP Session Expires timer is 1800.  I have changed both of these to something else and it made no difference.
I have also changed the min-SE in the associated CUBE and again, no change.
What logs are needed?  I have a PCAP between the jabber client and CUCM, CUBE debug ccsip messages or is it something from RTMT?
BUMP - anybody?
Enable the following for a test call please -
debug ccsip message
debug ccsip error
debug voice ccapi inout
Exactly 29 minutes and 28 seconds call clear from CUCM with cause code 41.  Debug of the failure output from CUBE attached
Logs are not complete. All I see is a SIP BYE.
I only run the debug for the time when the call failed on the associated CUBE system.. The SIP BYE is originated from CUCM with error code / cause = 41. I need to understand why CUCM is killing the call
You need the complete log. You can't just see a 41 in a BYE and interpret why is CUCM disconnecting the call.
Full call debug attached.  Call died at 17 minutes, that the first time I have seen that.
>> Your call seems cleared with cause=16 (referece Call-ID: f879de00-b4b10a95-199bb-bc71bac@172.27.199.11) 008565: Jul 15 09:07:09.971: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:01189761593@172.27.199.1:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 172.27.199.11:5060;branch=z9hG4bK1a5b7722d0c61 From: "The Purple Group" <02392006341>;tag=318492~4aca1d00-fcbd-60df-8ac5-ac9f97ba2d7d-27795643 To: <01189761593>;tag=CB74D308-F26 Date: Sun, 15 Jul 2018 08:49:25 GMT Call-ID: f879de00-b4b10a95-199bb-bc71bac@172.27.199.11 User-Agent: Cisco-CUCM11.0 Max-Forwards: 70 P-Asserted-Identity: "The Purple Group" <02392006341> CSeq: 102 BYE Reason: Q.850;cause=16 Session-ID: 0bc3723500105000a000f45c899da0d3;remote=a80cc56d33a91ddcb4cef186ab318492 Content-Length: 0] >> There is another BYE received from CUCM with cause=41 (reference Call-ID: da11e380-b4b103ac-19968-bc71bac@172.27.199.11), but it doesn't have the complete logs captured for that faulty call. 008366: Jul 15 08:49:31.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: BYE sip:01189761593@172.27.199.1:5060;transport=tcp SIP/2.0 Via: SIP/2.0/TCP 172.27.199.11:5060;branch=z9hG4bK1a5891a208ea5 From: "The Purple Group" <02392006341>;tag=318210~4aca1d00-fcbd-60df-8ac5-ac9f97ba2d7d-27795639 To: <01189761593>;tag=CB59D3B0-8BF Date: Sun, 15 Jul 2018 08:19:56 GMT Call-ID: da11e380-b4b103ac-19968-bc71bac@172.27.199.11 User-Agent: Cisco-CUCM11.0 Max-Forwards: 70 P-Asserted-Identity: "The Purple Group" <02392006341> CSeq: 102 BYE Reason: Q.850;cause=41 Content-Length: 0 //Suresh Please rate all the useful posts.
your call seems cleared with cause=16 (Call-ID: f879de00-b4b10a95-199bb-bc71bac@172.27.199.11)
Received:
From: "The Purple Group" <sip:02392006341@172.27.199.11>;tag=318492~4aca1d00-fcbd-60df-8ac5-ac9f97ba2d7d-27795643
To: <sip:01189761593@172.27.199.1>;tag=CB74D308-F26
Max-Forwards: 70
P-Asserted-Identity: "The Purple Group" <sip:02392006341@172.27.199.11>
CSeq: 102 BYE
Content-Length: 0]
 >> There is another BYE received from CUCM with cause=41 (Call-ID: da11e380-b4b103ac-19968-bc71bac@172.27.199.11), but it doesn't have the complete logs captured for that faulty call.
Received:
From: "The Purple Group" <sip:02392006341@172.27.199.11>;tag=318210~4aca1d00-fcbd-60df-8ac5-ac9f97ba2d7d-27795639
To: <sip:01189761593@172.27.199.1>;tag=CB59D3B0-8BF
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
