Call Disconnect after 30Min
Ralf.Bopp
a costumer has an analog phone connected to an ata186.
When he is calling out and the call lasts longer den 30Min , the call gets automaticaly disconnected.
The IP-Phones work without problems.
Is there a timer which disconnects calls after a period of time, especially for ata's ?
I found a maximum call duration timer, but that timer is set on 360Min.
Thanks for help
17 Replies 17
I just configured it with the same number as the 1st port.
Thanks for the reply, I found out in my case the problem was related to the firmware of the ATA. I upgraded it to 3
.2.4 and it works great now. Thanks again.
garg.atul
Try increasing the tcp timeout at PIX if it is in between.
