Call Disconnect - Busy Signal
Lulzim Islami
Hi There,
I have CUCM 7.1 and all calls are working fine through PRI line except Information Center and my Telco Help Desk Number. All numbers I can dial thru E1 PRI only 977 and 988 I'm not able to call them, it gives me a busy signal all the time. It use to work until few weeks but suddenly it stopped working.
Any help will be appreciated.
Thank you,
Router Config:
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g723ar53
codec preference 5 g723ar63
codec preference 6 g723r53
codec preference 7 g723r63
codec preference 8 g726r16
codec preference 9 g726r24
codec preference 10 g726r32
codec preference 11 g722-64
codec preference 12 g722-48
codec preference 13 g722-56
codec preference 14 g711ulaw
voice class h323 1
  h225 timeout tcp establish 4
dial-peer voice 2 voip
description Primary CUCM
answer-address .
destination-pattern [1-8]...
translate-outgoing calling 112
session target ipv4:10.150.10.2
voice-class codec 2
voice-class h323 1
no vad
dial-peer voice 3 voip
description Secondary CUCM
preference 1
answer-address .
session target ipv4:10.150.10.3
voice-class codec 2
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1 pots
description Incoming PSTN Calls
destination-pattern .T
incoming called-number .
direct-inward-dial
port 1/0:15
forward-digits all
and here is the debug:
081963: Nov 14 13:30:32.709 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
081964: Nov 14 13:30:32.711 UTC: //138426/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
081965: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Shemsije Rama Zogu
   ----- ccCallInfo IE subfields -----
   cisco-ani=1115
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=988
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
081966: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x1F0658C0, Call Info(
   Calling Number=1115,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=988(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=138426
081967: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/cc_api_call_setup_ind_common:
   Interface Type=0, Protocol=1
081968: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/ccCheckClipClir:
   In: Calling Number=1115(TON=Unknown, NPI=Unknown, Sc
3945voice#reening=User, Passed, Presentation=Allowed)
081969: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/ccCheckClipClir:
   Calling Party Number Is User Provided
081970: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/ccCheckClipClir:
   Out: Calling Number=1115(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
081971: Nov 14 13:30:32.711 UTC: //-1/80115175AE0D/CCAPI/cc_api_call_setup_ind_common:
   After Number Translation Checking:
   Calling Number=1115(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
081972: Nov 14 13:30:32.711 UTC: //138426/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=3, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
081973: Nov 14 13:30:32.711 UTC: //138426/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=4
081974: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
081975: Nov 14 13:30:32.711 UTC: :cc_get_feature_vsa malloc success
081976: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
081977: Nov 14 13:30:32.711 UTC:  cc_get_feature_vsa count is 7
081978: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
081979: Nov 14 13:30:32.711 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:550405856,feature_id:171738
081980: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
081981: Nov 14 13:30:32.711 UTC:  call_init_entry calle is 21218E10,callid is 138426
081982: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=138426
081983: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1115(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=988(TON=Unknown, NPI=Unknown))
081984: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=10.150.10.3, Hwidb=GigabitEthernet0/0
081985: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_incr_if_call_volume:
   Total Call Count=4, Voip Call Count=4, MMoip Call Count=0
081986: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_process_call_setup_ind:
   Event=0x20502118
081987: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=988, Call Transfer Consult Id=
081988: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
081989: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
081990: Nov 14 13:30:32.711 UTC: Comparing SSOpCode; 0x50 and 0x0
081991: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
081992: Nov 14 13:30:32.711 UTC: Comparing SSOpCode; 0x12 and 0x0
081993: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 988
081994: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
081995: Nov 14 13:30:32.71
3945voice#1 UTC: Comparing SSOpCode; 0x50 and 0x0
081996: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
081997: Nov 14 13:30:32.711 UTC: Comparing SSOpCode; 0x12 and 0x0
081998: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   No Matching Node
081999: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCallSetContext:
   Context=0x20DCE358
082000: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 138426 with tag 2 to app "_ManagedAppProcess_Default"
082001: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCallProceeding:
082002: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
082003: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   Unsupported MLPP Service Domain Network 0
082004: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
   Invalid MLPP Information
082005: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
   Precedence not above Routine
082006: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   BEFORE COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]
082007: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   AFTER COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]   DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
082008: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
   BEFORE COPY - SRC MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  DEST MLPP INFO:ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
082009: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_copy_mlpp_info:
082010: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
082011: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
082012: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
082013: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
082014: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
   VALIDATING MLPP INFO:- ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)]
082015: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_validate_mlpp_info:
082016: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_set_mlpp_info:
082017: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_is_precedence_mlpp_info:
082018: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x20DDCEC4, Progress Indication=NULL(0)
082019: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCheckClipClir:
   In: Calling Number=1115(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
082020: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCheckClipClir:
082021: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCheckClipClir:
082022: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=988, Digit Strip=TRUE
082023: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=Shemsije Rama Zogu, Final Destination Flag=TRUE,
   Guid=80115175-F89C-310A-AE0D-24020A8801D8, Outgoing Dial-peer=1
082024: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=1115
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=988
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
082025: Nov 14 13:30:32.711 UTC: //138426/80115175AE0D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x20566D30, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=1115,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=988(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
3945voice#Flag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
082026: Nov 14 13:30:32.711 UTC: //138427/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=4, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
082027: Nov 14 13:30:32.711 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
082028: Nov 14 13:30:32.713 UTC: :cc_get_feature_vsa malloc success
082029: Nov 14 13:30:32.713 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
082030: Nov 14 13:30:32.713 UTC:  cc_get_feature_vsa count is 8
082031: Nov 14 13:30:32.713 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
082032: Nov 14 13:30:32.713 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:550403840,feature_id:171739
082033: Nov 14 13:30:32.713 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
082034: Nov 14 13:30:32.713 UTC:  call_init_entry calle is 2121A5F0,callid is 138427
082035: Nov 14 13:30:32.713 UTC: //138426/80115175AE0D/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=138426, Bindee Call Id=138427
082036: Nov 14 13:30:32.713 UTC: //138427/80115175AE0D/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=138427
082037: Nov 14 13:30:32.713 UTC: //138427/80115175AE0D/CCAPI/cc_set_voice_port_value:
   CC_IF_TELEPHONY: Echo=0, Playout=0
082038: Nov 14 13:30:32.713 UTC: //138427/80115175AE0D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
082039: Nov 14 13:30:32.713 UTC: //138426/80115175AE0D/CCAPI/ccCallSetupRequest:exit@2607
082040: Nov 14 13:30:32.713 UTC: //138427/80115175AE0D/CCAPI/ccCallSetContext:
   Context=0x20DDCE78
082041: Nov 14 13:30:32.713 UTC: //138426/80115175AE0D/CCAPI/ccSaveDialpeerTag:
082042: Nov 14 13:30:32.713 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_set_outpulsed_digits:
   outpulsed_dialstring=988 set
082043: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x20566D30, Call Id=138427
082044: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=31, Retry Count=0)
082045: Nov 14 13:30:32.735 UTC: //138426/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
082046: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=138427
082047: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=31)
082048: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=FALSE)
082049: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallDisconnect:
   Cause Value=31, Call Entry(Disconnect Cause=31)
082050: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallDisconnect:
082051: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/ccCallDisconnect:
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
082052: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
082053: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x20566D30, Tag=0x0, Call Id=138427,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
082054: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
082055: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
082056: Nov 14 13:30:32.735 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
082057: Nov 14 13:30:32.735 UTC: :cc_free_feature_vsa freeing 20CE7EF8
082058: Nov 14 13:30:32.735 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
082059: Nov 14 13:30:32.735 UTC:  vsacount in free is 7
082060: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_delete_call_entry:
082061: Nov 14 13:30:32.735 UTC: //138427/80115175AE0D/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x20BB8E2C]
082062: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082063: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/ccGetCallGCID:
   Bad Call ID: callEntry=NULL
082064: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082065: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/ccSetCallGCID:
082066: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082067: Nov 14 13:30:32.735 UTC: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082068: Nov 14 13:30:32.735 UTC: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
082069: Nov 14 13:30:32.735 UTC: //138427/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082070: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
082071: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/ccCallDisconnect:
   Call Entry(Incoming=TRUE)
082072: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/ccCallDisconnect:
   Cause Value=31, Call Entry(Disconnect Cause=0)
082073: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/ccCallDisconnect:
082074: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_api_get_transfer_info:
082075: Nov 14 13:30:32.735 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
082076: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_decr_if_call_volume:
082077: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_decr_if_call_volume:
   Total Call Count=3, Voip Call Count=3, MMoip Call Count=0
082078: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1F0658C0, Tag=0x0, Call Id=138426,
082079: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_api_call_disconnect_done:
082080: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
082081: Nov 14 13:30:32.735 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
082082: Nov 14 13:30:32.735 UTC: :cc_free_feature_vsa freeing 20CE86D8
082083: Nov 14 13:30:32.735 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
082084: Nov 14 13:30:32.735 UTC:  vsacount in free is 6
082085: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_delete_call_entry:
   Total Call Count=4, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
082086: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_delete_call_entry:
   Total Call Count=3
082087: Nov 14 13:30:32.735 UTC: //138426/80115175AE0D/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x20BB7D24]
082088: Nov 14 13:30:32.735 UTC: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
082089: Nov 14 13:30:32.735 UTC: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
3945voice#un all
9 Replies 9
Chris Deren
Your dial peer destination-pattern is:
going to call agent (assuming CUCM), everything else goes out PSTN, is this what you want?
Can you post "debug isdn q931"?
HTH,
Chris
Hi Chris,
Yes, destination-pattern [1-8]... is my Call Agent CUCM, outgoing calls are going thru PSTN.
Here is the isdn debug:
3945voice#
082553: Nov 14 14:37:49.080 UTC: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 0385017011115
082554: Nov 14 14:37:49.080 UTC: ISDN Se1/0:15 Q931: Sending SETUP  callref = 0x13C0 callID = 0xFD2E switch = primary-net5 interface = User
082555: Nov 14 14:37:49.080 UTC: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x13C0
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Calling Party Number i = 0x0081, '0385017011115'
3945voice#
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '549411'
082556: Nov 14 14:37:49.118 UTC: ISDN Se1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x93C0
082557: Nov 14 14:37:49.258 UTC: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x93C0
        Progress Ind i = 0x8488 - In-band info or appropriate now available
        Progress Ind i = 0x8282 - Destination address is non-ISDN
3945voice#
082558: Nov 14 14:37:54.119 UTC: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x311E
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA98391
                Exclusive, Channel 17
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x0083, '038236681'
082559: Nov 14 14:37:54.119 UTC: ISDN Se1/0:15 Q931: Received SETUP  callref = 0xB11E callID = 0x7664 switch = primary-net5 interface = User
082560: Nov 14 14:37:54.121 UTC: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0xB11E
082561: Nov 14 14:37:54.193 UTC: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x93C0
        Date/Time i = 0x0C0B0E0F25
                Date (dd-mm-yr)   = 12-11-14
                Time (hr:mnt:sec) = 15:37:218
082562: Nov 14 14:37:54.193 UTC: %ISDN-6-CONNECT: Interface Serial1/0:29 is now connected to 549411 N/A
082563: Nov 14 14:37:54.193 UTC: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x13C0
082564: Nov 14 14:37:54.199 UTC: ISDN Se1/0:15 Q931: RX <- FACILITY pd = 8  callref = 0x93C0
        Facility i = 0x91A113020269E9020122300AA1053003020101820100
                Protocol Profile = Remote Operations Protocol
                0xA113020269E9020122300AA1053003020101820100
                Component = Invoke component
                        Invoke Id = 27113
                        Operation = AOCDChargingUnit
082565: Nov 14 14:37:54.203 UTC: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x311E
        Called Party Number i = 0x81, '1'
                Plan:ISDN, Type:Unknown
3945voice#
082566: Nov 14 14:37:54.405 UTC: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x311E
        Called Party Number i = 0x81, '4'
082567: Nov 14 14:37:54.597 UTC: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x311E
        Called Party Number i = 0x81, '5'
082568: Nov 14 14:37:54.801 UTC: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x311E
        Called Party Number i = 0x81, '0'
082569: Nov 14 14:37:54.905 UTC: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB11E
082570: Nov 14 14:37:54.907 UTC: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xB11E
3945voice#
082571: Nov 14 14:37:58.194 UTC: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xB11E
082572: Nov 14 14:37:58.224 UTC: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x311E
082573: Nov 14 14:37:58.224 UTC: %ISDN-6-CONNECT: Interface Serial1/0:16 is now connected to 038236681 N/A
082574: Nov 14 14:37:58.268 UTC: %ISDN-6-DISCONNECT: Interface Serial1/0:29  disconnected from 549411 , call lasted 4 seconds
3945voice#
The previous debug was from the number that i can dial, here is the debug from the number that I'm getting bussy signal:
3945voice#
082642: Nov 14 14:43:50.857 UTC: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 1200
082643: Nov 14 14:43:50.857 UTC: ISDN Se1/0:15 Q931: Sending SETUP  callref = 0x13CB callID = 0xFD39 switch = primary-net5 interface = User
082644: Nov 14 14:43:50.857 UTC: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x13CB
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '1200'
3945voice#
        Called Party Number i = 0x80, '988'
082645: Nov 14 14:43:50.877 UTC: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x93CB
        Cause i = 0x829F - Normal, unspecified
3945voice#un all
082646: Nov 14 14:43:53.898 UTC: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x93C9
        Display i = '1 UNITS'
3945voice#un all
OK, her you are only sending 3 digits, can you post "debug voice dialpeer" for the call that fails?
Chris
So, your destination pattern is expectoing 4 digits, yet your call comes in with 6 digits, is this the intent? Can you also post "debug voice dialpeer" and let us know what number you dialed, as there appears to be more than 1 call here.
Chris
Chris,
4 digits are my internal extensions and you're right there are 2 calls made previously, first dialed number is 549 411 which is working fine, and second debug is dialed number 988 on a same telco provider and gives me busy tone.
Here is the debug from dialed number 988.
3945voice#
082774: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1115, Called Number=988, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
082775: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=2
082776: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
082777: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpAssociateIncomingPeerCore:
082778: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpAssociateIncomingPeerCore:
082779: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchSafModulePlugin:
082780: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=988, Peer Info Type=DIALPEER_INFO_SPEECH
082781: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=988
082782: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
082783: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchSafModulePlugin:
   dialstring=988, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
082784: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
082785: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
082786: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
082787: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
082788: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchSafModulePlugin:
082789: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
082790: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=988, Called Number=988, Peer Info Type=DIALPEER_INFO_SPEECH
082791: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
082792: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
082793: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
082794: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
082795: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=988, Called Number=, Voice-Interface=0x0,
082796: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
082797: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
082798: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
082799: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
082800: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
082801: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
082802: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
082803: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
082804: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
082805: Nov 14 14:48:42.425 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
082806: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
3945voice#Calling Number=, Called Number=988, Peer Info Type=DIALPEER_INFO_SPEECH
082807: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
082808: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersCore:
082809: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchSafModulePlugin:
   dialstring=988, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
082810: Nov 14 14:48:42.425 UTC: //-1/8046C660070E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
3945voice#un all
All possible debugging has been turned off
3945voice#
As I said earlier the call is attempting to go out back to PSTN as it matches dial-peer 1, is this the intent? If you need it to go to CUCM then you need to add a dial-peer with matching destination-pattern, i.e. 9..
HTH, Please rate all usuful posts!
Chris
Chris,
Call is attemting to go out to the PSTN, this is the intent, but for some reason it is giving me busy signal? Can it be codec mismatch with my telco provider? All other destinations I'm able to call from same telco provider.
Hi there,
Any idea what could cause bussy signal on those specific dialed numbers?
