04-20-2014 09:18 PM - edited 03-16-2019 10:31 PM
I have CUCM 9 at HO and CUCME at branch office. The bandwidth between the two sites are 2 MB.
I configure Voip Dialpeer on CUCME pointing towards CUCM and H323 Gateway on CUCM. Now the issue is when Remote IP Phone call HO its ring but when end user pick the calls, call immediately drops. Same if we call from HO to Remote.
Am using G729.
Need urgent assistance
Thank You
04-21-2014 01:16 AM
Hi Muhammad,
You need to ensure that the codec specified on the voip dial peer towards cucm is set to use g729 and also the region setting between the IP phone and h323 gateway is g729. If there is a call leg that is not talking g729 then a transcoder would be needed.
Manish
04-24-2014 12:02 AM
Hi Manish
I configure the G792 on both the sides but still call is not coming and going.
Why we need transcoder.
Thank you
04-24-2014 12:07 AM
Hi Muhammad,
Please get the output of 'debug voice ccapi inout' from the h323 gateway for a test call.
Manish
