08-04-2020 05:40 PM
Hello
Currently, an ASA firewall is installed in front of the H.323 Gateway.
After installing the firewall, calls cannot be made during a call. All firewall policies are allowed.
When talking on the phone, it is disconnected after a few seconds without ring back tone.
If you remove the ASA firewall, the call will proceed normally.
The configuration diagram was uploaded as an attachment.
Thank you
08-04-2020 06:34 PM
08-04-2020 11:01 PM
What Mohammed describes above is a must for testing the performance of your system with the ASA, you can find an example/reference of disabling SIP inspection below:
https://community.cisco.com/t5/network-security/cisco-asa-sip-inspection/m-p/3734878
George
08-05-2020 05:49 PM - edited 08-05-2020 05:58 PM
Thank you for answer.
However, the global policy policy is set by default, but if you disable it, I wonder if there is any problem with the service.
And policy-map global_policy is h323 matched in Class-map like the attached file, so if you disable inspect h323, you think h323 communication is not correct, right?
Thank you
08-05-2020 10:49 PM
