Call failure after installing ASA firewall.
Yun Ho Ko
Hello
Currently, an ASA firewall is installed in front of the H.323 Gateway.
After installing the firewall, calls cannot be made during a call. All firewall policies are allowed.
When talking on the phone, it is disconnected after a few seconds without ring back tone.
If you remove the ASA firewall, the call will proceed normally.
The configuration diagram was uploaded as an attachment.
Thank you
>From ASA, global policy inspection, disable h323 h225 and h323 h245
inspection. Also disable sip inspection if you are using sip.
**** please remember to rate useful posts
George Sotiropoulos
What Mohammed describes above is a must for testing the performance of your system with the ASA, you can find an example/reference of disabling SIP inspection below:
https://community.cisco.com/t5/network-security/cisco-asa-sip-inspection/m-p/3734878
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thank you for answer.
However, the global policy policy is set by default, but if you disable it, I wonder if there is any problem with the service.
And policy-map global_policy is h323 matched in Class-map like the attached file, so if you disable inspect h323, you think h323 communication is not correct, right?
Thank you
The communication will continue to work. Disabling h323 won't cause a
problem.
