Call flow IP phone and PSTN
Arjun Kamble
Hi All,
Can somebody elaborate the call flow of outgoing call from Ip phone to PSTN and incoming call from PSTN to ip phone. Please provide me information as step by step.
1] Outgoing: IP phone to PSTN
2] Outgoing: IP phone to IP phone
3] Incoming: PSTN to IP phone
4] Incoming: IP phone to IP phone
Thank you,
Arjun Kamble
Pal, Yash
It completely depends on what VOIP environment do you have, if you have a Cisco VOIP (CUCM)environment then please find the flow below as per the given scenario:-
1) For outbound PSTN call from Cisco IP phone:- Cisco IP phone/DN->CUCM->H.323/MGCP/SIP Gateway->PSTN
2) For Inbound to Cisco IP phone from PSTN number:- PSTN->Telco/Mobile Operator->H.323/MGCP/SIP Gateway->CUCM->Cisco IP phone/DN
3) For Outbound IP phone to IP phone/VOIP call-> Cisco IP phone/DN-CUCM->Cisco IP phone/DN
4) For Inbound IP phone to IP phone/VOIP call-> Cisco IP phone/DN-CUCM->Cisco IP phone/DN
Above explained flows are just basic overview that how the calls flow in different scenarios however there are lots of technical stuffs involved behind these call flows.
I hope it helps you.
Yash pal
