06-20-2011 07:51 PM - edited 03-16-2019 05:33 AM
Hi all, can someone tell me how the call flow from PSTN to Cisco IP Phome (No IPCC) ?
06-20-2011 08:19 PM
This is something you should ask your local network administrator.
-Atul
06-20-2011 08:25 PM
Hi Atul, m just asking the concept .
06-20-2011 09:31 PM
This is a very generic scenario, it totally depends on the network topology.
-Atul
06-21-2011 04:22 AM
Most basic scenario is:
PSTN - GW - CUCM - IP Phone.
You would need to look at your whole CUCM/GW config to find out exactly what you're doing with the calls.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
