06-21-2011 12:33 AM - edited 03-16-2019 05:33 AM
Hello there,
I would like to know if the CUCM is compatible with Microsoft server 2008 and Microsoft Exchange server 2010.
Thanks.
Solved! Go to Solution.
06-21-2011 03:12 AM
CUCM doesn't care about Exchange, only Active Directory. The SRND has a chapter on LDAP Directory Integration which shows that the 2008 functional level is supported.
06-21-2011 01:39 AM
Hi Jonathon,
Is it for active directory integration?
Thanks and Regards,
Ashfaque
06-21-2011 02:33 AM
Yes, it is for Active Directory integration.
06-21-2011 03:12 AM
06-21-2011 03:32 AM
Thanks a lot for the information.
