Call Forward All to Different Numbers
BillFilt9
Is it possible to configure the side buttons on a 7961 to change the forwarding on the primary line to different numbers?  For example
Button 1 Call Forwards All to Voicemail
Button 2 Call Forwards All to Mobile
etc..
Jaime Valencia
No, at most all you can do is get another button there to do the same as the CFA softkey but no way to program anything else.
You would just press the button and then either dial the DN or press VM/speed dial.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
