IP Telephony and Phones
Labels
Resolved! How many List.xml?
I need to deploy a background image to our phones, we have different types- 7941, 42, 65 75 etc. The 7975, 65 are fine but I`m having issues with the 7942. The image size are all correct but when I select the background image on the phone of the 7941...
iptuser55 by Frequent Contributor
  • 348 Views
  • 2 replies
If customer is deploying CUPS 8.5 with CUPC (Cisco Unified Personal Communicator) is there any reason to put Cisco IP Communicator on their  computer as well?  Doesn’t CUPC replace IP Communicator for those customers running CUPS 8.5 with Callmanager...
Jason Aarons by Frequent Contributor
  • 801 Views
  • 5 replies
Hi,I have CME with 12 Port's FXO when some one call from outside i am getting unknown number i check with Telco the feature is there. i enable the following debug's• debug vpm signal• debug vtsp dsp• debug vtsp sessionFeb 27 13:33:31.572: %SYS-5-CONF...
I have a 2811 ISR with a voice card.  When I try to create "maximum sessions" for "dspfarm profile 1 conference" it shows a maximum available "0".  I am not using the 4 FXO ports at all and those DSPs are ripe for harvest.  I am not using the T1/PRO ...
mmedwid by Participant
  • 413 Views
  • 5 replies
I have a customer that has CME/CUE. That are also using gmail as their email system. I know gmail supports mailbox/account consolidation. Can I use that feature to pull voice mails from CUE to their gmail account (assuming the firewall rules are c...
crbates by Contributor
  • 544 Views
  • 2 replies
Resolved! Secure Call
I have a problem with secure call, my phones will not switch to secure mode when I call through a PBX. If I make a direct call (peer to peer), my phones will switch to secure mode.I read in the manual that the secure call establishment relies on exch...
