11-07-2017 12:25 AM - edited 03-17-2019 11:33 AM
Hi ,
Good Day .
I am working on a issue on the call forwarding on the skype for business 2015 .
My customer has integration of CUCM and SfB with SIP trunk . Inbound and Outbound Call from SfB user are fine and they are able to set the call forwarding to their mobile as well .
However the call forwarding only work on the internal call .
When an external call to the user , the call forwarding will not work and blocked at CUCM. I have capture the CCM logs on the call manager and found
Blocked call -- Suspect it is due to the calling number not authorize and with (+) in front .
002186812 |2017/10/30 20:40:50.084 |100 |SdlSig |DaReq |wait |Da(2,100,199,1) |Cdcc(2,100,207,3867) |2,100,63,1.40309^172.21.80.31^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=46707223 Fqdn=pi=0si1 Cgpn=tn=0npi=0nd=+6138XXXXXXXUser=Host=XXXXXX.comPort=0PassWord=Madder=Transport=4mDisplayName=RawUrl=pi=1si0 DialedNum=tn=0npi=1nd=004XXXXXXXXUser=004XXXXXXXXHost=192.168.X.XPort=5060PassWord=Madder=Transport=4mDisplayName=RawUrl=sip:XXXXXXXX@192.168.X.X;user=phonepi=0si1 requestID=0 DigitAnalysisComplexity=0 CallingUser= IgnoreIntercept=0
002186813 |2017/10/30 20:40:50.084 |100 |SdlSig |DaRes |setup_da |Cdcc(2,100,207,3867) |Da(2,100,199,1) |2,100,63,1.40309^172.21.80.31^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=46707223 Block NoPotentialMatchesExist OnNetpatternUsage =2requestID =0
Need some help to suggest how to fixed it .
Thanks.
Best regards,
kelvin
11-07-2017 02:15 AM
01-08-2018 12:55 AM
Thanks for your reply .
Sorry, I should provide more info .
Actually the calling number is "+6138XXXXXXX" where it is an external number. The call flow as below
"+6138XXXXXXX" > Cisco Voice gateway > CUCM > Skype for business > 8XXX > Call forward > CUCM > Cisco Voice gateway > mobile 004XXXXXXXX .
I am suspecting when the Skype for business call forward it to the mobile 004XXXXXXXX , it may be blocked by CUCM as it see the calling number are external number "+6138XXXXXXX" .
Is the translation rule applicable for the Calling number ?
01-08-2018 08:31 PM
04-12-2018 08:38 PM
04-12-2018 08:53 PM
04-12-2018 09:00 PM
