Call forward not working from outside Call SIP Trunk
jchevalon
Dear,
I installed a 2901 ISR CCME 10.5 with a SIP Trunk from an external supplier.
The call forwarding does not work when a call is received from outside.
If I call from an internal phone on a phone with a call forward to external or internal number it's work
I work on the problem since 2 months without success, I do not understand.
I think the problem may be my dial peer or translation Rule,
There she works with luck because I am quite newbie.
I join debug and Show Run in attachment
Thank you in advance for your help.
it is not a lot but you'll have all my gratitude :)
Vivek Batra
Configure the following;
voice service voip
    no supplementary-service sip moved-temporarily
- Vivek
Vivek Batra
voice service voip
- Vivek
I have additional concerns
When calls are being forwarded to an external phone. The number displayed is not like the calling number but to a Russian number.
do you have an idea?
thanks a lot
Thank you, you saved my life and lots of Advil
