Call Forward Original Party Number
Siva chinap
Level 5
Level 5
Dear Gents,
I have a clarification on call forwarding , If i forward all my calls to mobile , when some body reaches my extension the forwarded call shows as main pri number instead of my did number. how can i configured to c my orginal caller id, during call forward?
10 Replies 10
Jitender Bhandari
Hi Shiva,
What is the call flow, example
IP Phone -- CUCM -- IP Phone ( CFA) -- MGCP -- PRI --- PSTN
what is the gateway type MGCP\h323\SIP.
Can you provide more details.
JB
Dear Jitendar,
Below is the Call folow
IP Phone -- CUCM -- IP Phone ( CFA) -- H.323 -- PRI --- PSTN
Hi Shiva,
Under GW configuration check below.
Call Routing Information - Outbound Calls
Calling Party Selection
Any outbound call on a gateway can send directory number information. Choose which directory number is sent:
  • Originator—Send the directory number of the calling device.
  • First Redirect Number—Send the directory number of the redirecting device.
  • Last Redirect Number—Send the directory number of the last device to redirect the call.
  • First Redirect Number (External)—Send the directory number of the first redirecting device with the external phone mask applied.
  • Last Redirect Number (External)—Send the directory number of the last redirecting device with the external phone mask applied.
Calling Party Presentation
Choose whether you want the Cisco Unified Communications Manager to allow or restrict the display of the calling party phone number.
Choose Default if you do not want to change calling line ID presentation. Choose Allowed if you want Cisco Unified Communications Manager to send "Calling Line ID Allowed" on outbound calls. Choose Restricted if you want Cisco Unified Communications Manager to send "Calling Line ID Restricted" on outbound calls.
For more information about this field, see topics related to Calling Search Space configuration settings in the Cisco Unified Communications Manager System Guide.
JB
What needs to be configured, inorder to work?
Hi SIva,
Utilize calling party selection as "First Redirect Number (external)".
Save and reset the H323 gateway page on CUCM.
Hitesh
I did that still its not working
Hi Siva,
If you did save and reset the gateway page after making the change and it still did not work, I would recommend to open a TAC case to assist you from logs for the same.
Hitesh
Thanks for your prompt response,
Can u send me the steps how i can utilize the calling party section, can u give me some example scenarios.
Hi Siva,
If you go under the H323 GW page, you shall see a setting "Calling party Selection" as JB described above.
You just need to drop down the menu and select an appropriate one according to your requirement.
Now, let's say you have the following call example:
Original calling number : 987654321
Phone : 23452  with EPNM: 9999923452
Forwarded number : 765443298
Number going out with CFA with settings::
Originator  : 987654321
First Redirect : 23452
First Redirect (External) : 9999923452
Hope this helps!
Hitesh
Were did u configured this?
