CDR DETAIL ON MEDIA INFORMATION
Siva chinap
Level 5
Level 5
Hi All,
I am trying to get the information on outbound calls , when i analyse the CDR Detail Media information  Org Pkts recieved  and Destination Pkts recieved showing null... Attached screenshot for reference.
If you read the bug notes, It doesn't work if you are using SIP endpoints (this includes any model of phone that you register with SIP).
If you use older phone models, or any phone that uses SCCP to register, then it will work.
8 Replies 8
Aaron Harrison
hi
In your CDR load settings in CAR, uncheck 'CDR only' - this allows CMRs to be loaded also. It's the worst named checkbox in Cisco history... 'enable CMR' would have been better.
Bear in mind that you will still see null for some source/destinations, e.g. some types of gateway.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Dear Aaron,
Thanks for your prompt response,
After unchecking CDR , still we are facing the same issue. It's not getting updated.
hsood
Hi Siva,
Is the call going out via a SIP trunk?
If it is so, then the calls would not have the CMR data unless the SIP BYE message has the details like "packets received" and "packets sent" which only few providers support.
Hitesh
Dear Hitesh,
Calls are going through H.323 Gateways.We are not using any SIP Trunk in our deployment.
erikasasaki
If your originating device is a SIP endpoint, there is a bug for this that CMR information is not being updated accurately.
CSCub07733
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCub07733/?referring_site=bugquickviewredir
No workaround or known fixed release has been provided on that bug at this time.
SCCP endpoints are not affected by this bug.
Dear Eadsasaki,
We are using SIP endpoint CP 8841 and 8851 phone models. We are not using any SIP trunk, We are using H.323 Gateway. Stil will this work or not?
Thanks Ead,
It's very much useful information.
