03-25-2013 12:41 PM - edited 03-16-2019 04:26 PM
Dear all
I have cucm 8.6 and DID range 22270800 to 22270899
My problem is
When My mobile 97504865 calling cisco phone ext 852 with mask 22270XXX and this cisco phone is forwarded call to another mobile 99432186
The destination phone is ringing but give me wrong number it gave me
22270865 (the first five numbers from the mask then the last three numbers from last the calling numbers )
How to solve this issue
Plz advice me asap
Thanks all
03-25-2013 01:30 PM
Dear friend
22270865 is the number of your circuit or nnumber of what , plaase advise . Share also the configuration of your gateway.
thank you
please rate , if this will help
03-26-2013 12:46 AM
222270865 , yes in the same range and it is DID number
show run :
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 10.10.1.1 10.10.1.20
ip dhcp excluded-address 192.168.51.1 192.168.51.100
ip dhcp excluded-address 192.168.1.1 192.168.1.200
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.10
dns-server 192.168.1.11 192.168.1.12
ip dhcp pool VOICE
network 10.10.1.0 255.255.255.0
default-router 10.10.1.5
option 150 ip 10.10.1.10
ip dhcp pool Q-sys
network 192.168.51.0 255.255.255.0
default-router 192.168.51.1
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.200.200.50
ipv4 10.10.10.5
ipv4 10.10.1.10
ipv4 10.200.200.253
ipv4 10.200.200.243
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0
modem passthrough nse codec g711ulaw
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
license udi pid CISCO2901/K9 sn FCZ1624711H
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
description ## Connected to Fasttlco P2P ##
ip address 10.101.6.18 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description ## Internal Network ##
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.10.15 255.255.255.0
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
interface GigabitEthernet0/1.70
encapsulation dot1Q 70
ip address 192.168.51.1 255.255.255.0
interface GigabitEthernet0/1.90
encapsulation dot1Q 90
ip address 10.10.1.5 255.255.255.0
ip helper-address 10.10.1.5
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.1.5
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.10
ip route 10.200.200.0 255.255.255.0 10.101.6.17
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
sccp local GigabitEthernet0/1.90
sccp ccm 10.10.1.10 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1.90
associate ccm 1 priority 1
associate profile 2 register mtparc
associate profile 1 register xcoder
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
no ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
sccp
sccp ccm group 1
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dspfarm profile 2 mtp
codec pass-through
maximum sessions hardware 10
dial-peer voice 10 voip
tone ringback alert-no-PI
description ## OUTGOING CALL ##
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
session protocol sipv2
session target ipv4:10.200.200.243
incoming called-number .T
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 20 voip
description ## INCOMING CALL ##
destination-pattern 222708..
session target ipv4:10.10.1.10
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
no vad
sip-ua
gatekeeper
shutdown
line con 0
password cisco1
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco1
logging synchronous
login
transport input all
line vty 5 15
password cisco1
logging synchronous
login
transport input all
scheduler allocate 20000 1000
ntp master 5
end
no ipv6 cef
ip source-route
ip cef
ip dhcp pool DATA
ip dhcp pool VOICE
ip dhcp pool Q-sys
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
ipv4 10.200.200.50
ipv4 10.10.10.5
ipv4 10.10.1.10
ipv4 10.200.200.253
ipv4 10.200.200.243
sip
voice class codec 1
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
no ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
sccp
sccp ccm group 1
codec g729r8
codec g711ulaw
codec g711alaw
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
no ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
sccp
sccp ccm group 1
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
codec pass-through
codec g711ulaw
no vad
codec g711ulaw
no vad
sip-ua
gatekeeper
shutdown
line con 0
password cisco1
login
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password cisco1
logging synchronous
login
transport input all
line vty 5 15
password cisco1
logging synchronous
login
transport input all
ntp master 5
end
03-26-2013 04:09 AM
This is a sip based PSTN. You may be experiencing a diverison header issue...
Can you send me do another test call and send
"debug ccsip messages"
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-28-2013 01:35 AM
Hi aokanlawon
thanks it is done and the problem was from ISP
thanks
03-28-2013 01:36 AM
Hi islam
thanks
