call from IP-network to mobile network through AS5350
jouk
I have AS5350 connected to the city telephon network by ISDN PRI. When the call from IP-network to the mobile phone of city network is occure and mobile phone in service - every thing is work. But when the mobile phone out of service the calling side must hear the automatic announcement from mobile network than subscriber out of service. But instead of this after 15-20 seconds Cisco back the busy tone. How can solve this problem
gogasca
Level 10
Level 10
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tvr/vrht_p2.htm#wp1110694
Try adding:
progress_ind alert enable 8
In the dial-peer POTS used for outgoing calls.
And
voice rtp send-recv
in config mode.
If that doesnt help please upload your sh run.
and debug voice ccapi inout for a failed call.
It still dose not work, here is sh run
How can i show you deb ccapi it is too long ?
version 12.3
service timestamps debug datetime localtime
service timestamps log datetime msec localtime show-timezone
boot-start-marker
no boot startup-test
boot-end-marker
resource-pool disable
clock timezone MSK 3
clock summer-time MSD recurring last Sun Mar 2:00 last Sun Oct 2:00
tdm clock priority 1 3/0
spe default-firmware spe-firmware-1
no ip cef
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback none
voice class codec 701
codec preference 1 g729r8
codec preference 2 g723r63
codec preference 3 g729br8
codec preference 4 g723r53
codec preference 5 g726r16
codec preference 6 g726r24
codec preference 7 g723ar63
codec preference 8 g723ar53
voice class cause-code 1
no unassigned-number
user-busy
controller E1 3/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 3/1
framing NO-CRC4
pri-group timeslots 1-16
gw-accounting aaa
translation-rule 1
translation-rule 2
interface FastEthernet0/0
ip address xxxxxx 255.255.255.224
ip access-group 101 in
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
interface Serial3/0:15
no ip address
isdn overlap-receiving T302 20000
isdn incoming-voice modem
isdn map address .* plan isdn type unknown
isdn calling-number 00000
isdn T309-enable
isdn sending-complete
no cdp enable
interface Group-Async0
description Group Async Interface
ip unnumbered FastEthernet0/0
no ip proxy-arp
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
load-interval 30
async mode dedicated
peer default ip address pool CISCO5350
ppp authentication pap chap
ppp authorization use-radius
ppp accounting use-radius
group-range 1/00 1/59
access-list 101 x
access-list 101 x
access-list 101 x
access-list 101 x
access-list 101 x
access-list 101 x
radius-server host xxxx auth-port 1812 acct-port 1813 key xxxx
radius-server timeout 60
radius-server directed-request
radius-server vsa send accounting
radius-server vsa send authentication
call application voice debit tftp://xxxx
call application voice debit uid-len 5
call application voice debit language 1 ru
call application voice debit set-location ru 0 tftp://xxxxx
voice-port 3/0:D
input gain 4
echo-cancel coverage 64
cptone RU
bearer-cap 3100Hz
voice-port 3/1:D
dial-peer cor custom
dial-peer voice 1 voip
destination-pattern [1-9]T
progress_ind setup enable 3
voice-class codec 701
session target ipv4:xxxx
tech-prefix 011
no vad
dial-peer voice 3 pots
huntstop
destination-pattern 99544......
direct-inward-dial
port 3/0:D
forward-digits 8
prefix 1
dial-peer voice 6 pots
application debit
incoming called-number 11112
port 3/0:D
forward-digits all
dial-peer voice 7 pots
incoming called-number [0-9]T
direct-inward-dial
dial-peer voice 8 pots
application data_dialpeer
incoming called-number 11111
port 3/0:D
gateway
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
exec-timeout 0 0
password xxxxx
login authentication vty-in
line 1/00 1/59
exec-timeout 0 0
no flush-at-activation
no modem callout
modem Dialin
exec-character-bits 8
special-character-bits 8
transport preferred none
transport input all
autoselect during-login
autoselect ppp
no scheduler allocate
ntp clock-period 17179800
ntp update-calendar
ntp server xxxxxxx
ntp server xxxxxxx
end
