Call handler hours of operation
Douglas Turner
I am using unity 8.5 and have setup multiple call handlers. One of the departments want their call handler to send calls to the receptionist from 9-12 and 1-5. During off hours and the 12-1 lunch hour they wants the calls to go directly to voicemail. Could someone please let me know how to configure this. Thank you
Jaime Valencia
Configure the schedule accordingly, and then the routing behavior you want, under the standard and closed greetings.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
i also normally setup the schedules on CUCM versus anything. this does depend on your setup but all departments have a pilot so what i do is use Time of Day
basically create time periods
assign the time periods to schedules (like working, non-working, lunch etc)
create partitions and assign the scehdules to each partitions
create a CSS for TOD and assign the partitions
then create Translations Patterns. basically if you have department say Sales and its pilot is 5000
translations will say -5000 route to X based on this time but route to Y based on another time.
not sure why i dont use the UNITY schedules because its seems like a lot right...
Dealing with UCXN schedules is a lot easier than time of day routing on CUCM, especially if the call is in UCXN already, makes not sense to do it in CUCM.
HTH,
Chris
