ā08-22-2012 05:53 AM - edited ā03-16-2019 12:49 PM
Hi Experts
Here in our setup the call is getting here and there some time
The call flow is like
ipphone-----cucm---h323vg---pstn(telco)
the calling number is 7099 and the called number is 94430632 the call is getting connected and it is disconnecting automaticaly and some time the call getting disconnect while ringing
cucm version is 8.6.2.20000-2
ios version c2800nm-spservicesk9-mz.124-24.T6.bin
this call routing through a fxo port even that is same for pri as well
Please find the debug and help me to reslove the issue
cc_api_call_setup_ind_common:
cisco-username=Raja RAHMAN
----- ccCallInfo IE subfields -----
cisco-ani=7099
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=94430632
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Aug 22 10:42:32.937: //-1/800FB6299F12/CCAPI/cc_api_call_setup_ind_common:
Interface=0x47CC2640, Call Info(
Calling Number=7099,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=94430632(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=16067
*Aug 22 10:42:32.937: //-1/800FB6299F12/CCAPI/ccCheckClipClir:
In: Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Aug 22 10:42:32.937: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 22 10:42:32.937: :cc_get_feature_vsa malloc success
*Aug 22 10:42:32.937: cc_get_feature_vsa count is 8
*Aug 22 10:42:32.937: :FEATURE_VSA attributes are: feature_name:0,feature_time:1263271584,feature_id:16067
*Aug 22 10:42:32.937: //16067/800FB6299F12/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=94430632(TON=Unknown, NPI=Unknown))
*Aug 22 10:42:32.937: //16067/800FB6299F12/CCAPI/cc_process_call_setup_ind:
Event=0x48312C28
*Aug 22 10:42:32.937: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 94430632
*Aug 22 10:42:32.937: //16067/800FB6299F12/CCAPI/ccCallSetContext:
Context=0x4B1ADA1C
>>>>CCAPI handed cid 16067 with tag 100 to app "_ManagedAppProcess_Default"
*Aug 22 10:42:32.937: //16067/800FB6299F12/CCAPI/ccCallProceeding:
*Aug 22 10:42:32.941: //16067/800FB6299F12/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=210, Params=0x4B1996E4, Progress Indication=NULL(0)
*Aug 22 10:42:32.941: //16067/800FB6299F12/CCAPI/ccCheckClipClir:
Destination Pattern=9[2-8]......, Called Number=94430632, Digit Strip=TRUE
Redirect Number=, Display Info=Raja RAHMAN
Account Number=Raja RAHMAN, Final Destination Flag=TRUE,
Guid=800FB629-64B4-4103-9F12-EF02C0A80B6A, Outgoing Dial-peer=210
*Aug 22 10:42:32.941: //16067/800FB6299F12/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=7099
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=94430632
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*Aug 22 10:42:32.941: //16067/800FB6299F12/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x483759B0, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=7099,(Calling Name=Raja RAHMAN)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=94430632(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=210, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Aug 22 10:42:32.941: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 22 10:42:32.941: :cc_get_feature_vsa malloc success
*Aug 22 10:42:32.941: cc_get_feature_vsa count is 9
*Aug 22 10:42:32.941: :FEATURE_VSA attributes are: feature_name:0,feature_time:1263271360,feature_id:16068
*Aug 22 10:42:32.941: //16068/800FB6299F12/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Aug 22 10:42:32.941: //16068/800FB6299F12/CCAPI/ccCallSetContext:
Context=0x4B199694
*Aug 22 10:42:32.941: //16067/800FB6299F12/CCAPI/ccSaveDialpeerTag:
*Aug 22 10:42:32.945: //16068/800FB6299F12/CCAPI/cc_api_call_proceeding:
Interface=0x483759B0, Progress Indication=NULL(0)
*Aug 22 10:42:32.945: //16065/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Nominator=0x49E2FC70, Params=0x49E2FC48, Call Id=16065
*Aug 22 10:42:34.197: //16068/800FB6299F12/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x483759B0, Call Id=16068
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
*Aug 22 10:42:34.197: //16067/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
*Aug 22 10:42:34.197: //16068/800FB6299F12/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=16068
*Aug 22 10:42:34.197: //16068/800FB6299F12/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
*Aug 22 10:42:34.201: //16068/800FB6299F12/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x483759B0, Tag=0x0, Call Id=16068,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Aug 22 10:42:34.201: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 22 10:42:34.201: :cc_free_feature_vsa freeing 4B4BFDB8
*Aug 22 10:42:34.201: vsacount in free is 8
*Aug 22 10:42:34.205: //16067/800FB6299F12/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=207, Params=0x4B1A0914, Progress Indication=NULL(0)
*Aug 22 10:42:34.205: //16067/800FB6299F12/CCAPI/ccCheckClipClir:
Guid=800FB629-64B4-4103-9F12-EF02C0A80B6A, Outgoing Dial-peer=207
*Aug 22 10:42:34.205: //16067/800FB6299F12/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=7099
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=94430632
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*Aug 22 10:42:34.205: //16067/800FB6299F12/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x48366050, Interface Type=6, Destination=, Mode=0x0,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=207, Call Count On=FALSE,
*Aug 22 10:42:34.205: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 22 10:42:34.205: :cc_get_feature_vsa malloc success
*Aug 22 10:42:34.205: cc_get_feature_vsa count is 9
*Aug 22 10:42:34.205: :FEATURE_VSA attributes are: feature_name:0,feature_time:1263271360,feature_id:16069
*Aug 22 10:42:34.205: //16069/800FB6299F12/CCAPI/ccIFCallSetupRequestPrivate:
*Aug 22 10:42:34.205: //16069/800FB6299F12/CCAPI/ccCallSetContext:
Context=0x4B1A08C4
*Aug 22 10:42:34.205: //16067/800FB6299F12/CCAPI/ccSaveDialpeerTag:
*Aug 22 10:42:34.209: //16069/800FB6299F12/CCAPI/cc_api_call_proceeding:
Interface=0x48366050, Progress Indication=NULL(0)
*Aug 22 10:42:37.233: //16069/800FB6299F12/CCAPI/cc_api_call_alert:
Interface=0x48366050, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
*Aug 22 10:42:37.233: //16067/800FB6299F12/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Aug 22 10:42:37.233: //16069/800FB6299F12/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
*Aug 22 10:42:37.233: //16067/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4B299230, callID1=0x3EC3, callID2=0x3EC5, tag=0x0)
(confID=0x4B299230, callID1=0x3EC3, gcid=0-0-0-0, tag=0x0)
*Aug 22 10:42:37.233: //16069/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4B299230, callID2=0x3EC5, gcid=0-0-0-0, tag=0x0)
*Aug 22 10:42:37.233: //16067/800FB6299F12/CCAPI/ccConferenceCreate:
Conference Id=0x4B299230, Call Id1=16067, Call Id2=16069, Tag=0x0
*Aug 22 10:42:37.233: //16067/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Aug 22 10:42:37.233: cc_api_get_xcode_stream : 4534
*Aug 22 10:42:37.233: //16067/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2540, Source Interface=0x47CC2640, Source Call Id=16067,
Destination Call Id=16069, Disposition=0x0, Tag=0x0
*Aug 22 10:42:37.237: //16069/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2540, Source Interface=0x48366050, Source Call Id=16069,
Destination Call Id=16067, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/cc_generic_bridge_done:
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2540, Destination Call Id=16069)
*Aug 22 10:42:37.237: //16069/800FB6299F12/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2540, Destination Call Id=16067)
*Aug 22 10:42:37.237: //16069/800FB6299F12/CCAPI/cc_api_caps_ind:
Destination Interface=0x47CC2640, Destination Call Id=16067, Source Call Id=16069,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/cc_api_caps_ind:
Destination Interface=0x48366050, Destination Call Id=16069, Source Call Id=16067,
Modem=0x2, Codec Bytes=160, Signal Type=2)
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5205)
*Aug 22 10:42:37.237: //16069/800FB6299F12/CCAPI/cc_api_caps_ack:
*Aug 22 10:42:37.237: //16067/800FB6299F12/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2540, Call Id1=16067, Call Id2=16069
*Aug 22 10:42:37.241: //16069/800FB6299F12/CCAPI/cc_api_voice_mode_event:
Call Id=16069
Call Entry(Context=0x4B1A08C4)
*Aug 22 10:42:37.241: //16069/800FB6299F12/CCAPI/cc_api_call_connected:
Interface=0x48366050, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Aug 22 10:42:37.241: //16067/800FB6299F12/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=16067
*Aug 22 10:42:37.241: //16069/800FB6299F12/CCAPI/cc_api_get_called_ccm_detected:
*Aug 22 10:42:37.245: //16067/800FB6299F12/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
*Aug 22 10:42:37.245: //16069/800FB6299F12/CCAPI/cc_api_get_called_ccm_detected:
Call Entry(Connected=TRUE, Responsed=TRUE)
*Aug 22 10:42:37.245: //16067/800FB6299F12/CCAPI/ccCallNotify:
*Aug 22 10:42:37.253: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x480A25B8, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
*Aug 22 10:42:37.253: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 22 10:42:37.253: :cc_get_feature_vsa malloc success
*Aug 22 10:42:37.253: cc_get_feature_vsa count is 10
*Aug 22 10:42:37.253: :FEATURE_VSA attributes are: feature_name:0,feature_time:1263271136,feature_id:16070
*Aug 22 10:42:37.253: //16070/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Aug 22 10:42:37.253: //16070/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x4B278958
*Aug 22 10:42:37.253: //16070/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Interface=0x480A25B8, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
*Aug 22 10:42:37.253: //16065/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x18E00, Params=0x49E2FFB0, Call Id=16065
*Aug 22 10:42:37.253: //16065/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x480A25B8, Call Id=16065
*Aug 22 10:42:37.257: //16066/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x49E2FC38, callID1=0x3EC2, callID2=0x3EC6, tag=0x0)
(confID=0x49E2FC38, callID1=0x3EC2, gcid=0-0-0-0, tag=0x0)
*Aug 22 10:42:37.257: //16070/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x49E2FC38, callID2=0x3EC6, gcid=0-0-0-0, tag=0x0)
Conference Id=0x49E2FC38, Call Id1=16066, Call Id2=16070, Tag=0x0
*Aug 22 10:42:37.257: //16070/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2541, Source Interface=0x480A25B8, Source Call Id=16070,
Destination Call Id=16066, Disposition=0x0, Tag=0x0
Call Entry(Conference Id=0x2541, Destination Call Id=16070)
Call Entry(Conference Id=0x2541, Destination Call Id=16066)
*Aug 22 10:42:37.257: //16065/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
*Aug 22 10:42:37.265: //16066/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2541, Source Interface=0x47CA840C, Source Call Id=16066,
Destination Call Id=16070, Disposition=0x0, Tag=0x0
*Aug 22 10:42:37.265: //16066/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
*Aug 22 10:42:37.265: //16070/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x0, Params=0x49E2F718, Call Id=16070
*Aug 22 10:42:37.265: //16066/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2541, Call Id1=16066, Call Id2=16070
*Aug 22 10:42:37.269: //16070/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x480A25B8, Call Id=16070
*Aug 22 10:42:37.269: //16070/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Nominator=0x49E2FC70, Params=0x49E2FC48, Call Id=16070
*Aug 22 10:42:37.277: //16067/800FB6299F12/CCAPI/cc_api_caps_ind:
*Aug 22 10:42:37.277: //16067/800FB6299F12/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5206)
*Aug 22 10:42:37.277: //16069/800FB6299F12/CCAPI/cc_api_caps_ack:
*Aug 22 10:42:37.281: //16069/800FB6299F12/CCAPI/cc_api_voice_mode_event:
Call Id=16069
Call Id=16069
*Aug 22 10:42:37.297: //16070/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x18E00, Params=0x49E2FFB0, Call Id=16070
*Aug 22 10:42:37.297: //16070/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
*Aug 22 10:42:37.297: //16070/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
*Aug 22 10:43:40.929: //-1/125B7AD982EC/CCAPI/cc_api_display_ie_subfields:
Dial peer :
dial-peer voice 210 pots
destination-pattern 9[2-8]......
fax rate disable
port 0/3/0
forward-digits 7
pots config :
voice-port 0/3/0
supervisory disconnect dualtone mid-call
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx 7000
caller-id enable
ā08-22-2012 06:32 AM
Cause 34 means
34
No circuit/channel is available. No B-channels are available to make the selected call.
Are you sure your PRI/FXO is working properly and properly configured?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā08-22-2012 07:02 AM
HI
this was working before normaly . it is happening in both fox and pri even some time with voip calls .
The above mention call it is routing through fxo
