Call Legs between h323 gateway and CUCM 7
techguy
Level 4
Level 4
Hi ,
Fo Inbound Calls
PSTN------POTS Dialpeer------VOIP Dialpeer------CUCM and then extension
For Outbound Call
Extension to CUCM------VOIP Dialpeer------POTS Dialpeer------PSTN
Voip dialpeers are used between gateway to CUCM connection. Am i right?
If so, then route patterns are used between CUCM to gateway connection. Please correct me if i am wrong. Thanks
sumimanc
Yes Voip Dial-peers are used to communicate on Ip legs (between CUCM and Voice Gateway) and POTS dial-peers used to communicate between VGW and PSTN
IP Phone---CUCM---(matches RP--> RL--->RG)---pointing towards the voice gateway but for this call leg it has to match the inbound dial-peer. So the voip dial-peer will match as an inbound dial-peer and the pots dial-peer will be outbound dial-peer
FOr both inbond call leg and outbound call leg , it matches inbound dial-peer and outbound dial-peers respectively.
So for outbound call from IP phone
IP phone---CUCM------>Inbound Voip dial-peer---->VGW---pOTS outbound dial-peer --->PSTN
For incming call from PSTN
          IP phone------CUCM<-------Outbound Vop dial-peer<--------VGW<-----Inbound Pots Dial-peer-<---PSTN
Same Dial-peer can act as Inbound dial-peer and Outbound Dial-peer
PS:Rate useful posts.
sumit
I have only one VOIP Dialpeer. It will be inboud voip dial peer for outboud and outbound dial peer for incoming call at the same time ???
Below is the Criteria to Match Inbound Dial-peer for Voip dial-peers
1) Incoming called-number : It will look for the this command in the dial-peers , it will match the number in tis command against the called number(DNIS)
2) Answered Address command L: If Incoming called numbeer command is  not there then it will look for answered addrss command .it will match the number in this command against the calling number(ANI)
3) Destination Pattern :If Answered address is also not there then it will look for answered addrss command .it will match the number in this command against the calling number(ANI)
So If you have only one dial-peers and you want to make it as inbound dial-peers for outbound calls and outgoing dial-peers for inbound calls,you can configure a dial-peer like this
Dial-peer voice 1 voip
incoming called number .                          < it will match with every called number >
destination-patern 2...
session target ipv4:
While making a call , you can run debug voip ccapi inout to see which dial-peers are being matched as incoming dial-peer and outgoing dial-peers
PS: Please rate useful posts.
sumit
