Call M Bulk Admin
kalbasha0
Current environment is Cisco Call M Ver7.12.
Current users are imported via AD utilizing CCM Authentication & enable Synchronizing method
Currently we are using a Cisco 7942
Was successfully able to import all phones into CCM utilizing Bulk admin, however
Is there a way to use BA to associate the users with the devices and modify user role and group?
Thx
You can add phones associated with users from 'Bulk Admin > Phones and Users > Insert Phones with Users', you can find the detail method from bulk administration guide. Also, if you want to modify the user role/group you can do it from 'Bulk Admin > Users > Update Users'.
Bulk Administration Guide for 7.1.2 can be your great help!
Md. Mijanur Rahman
HI Mijanur Rahman
Since the users first & last name \ password are imported via Active Directory, 'Bulk Admin > Phones and Users > Insert Phones with Users' won’t work.
Also ’Bulk Admin > Users > Update Users' doesn't give the options to modify Role \ group
thx
hi, email me, I know of a more flexible bulk tool
saschamonteiro [at] hotmail [dot] com
