09-02-2018 02:25 AM - edited 03-18-2019 12:31 PM
Hello Everyone,
I have a customers who is still running call manager 4.1 in his premises and he is not going to upgrade due to some financial crisis going on in his company.
They have 2 serves publisher and subscriber. The Publisher server failed to motherboard failure now I have to recover the Publisher Server your help will be appreciated.
Solved! Go to Solution.
09-03-2018 07:35 AM
Not as far as I can remember, I suggest you try to find some documentation on BARS that might be on the internet to doublecheck all the steps, as it has been a very long time since I've done that procedure.
09-02-2018 11:39 AM
Assuming you have all the media to do so, and an MCS which supports CUCM, you'd need to reinstall your server with the same release you're running (pretty much the same reqs as any current release for a DRS restore) and then do a BARS restore of a backup from the server.
09-02-2018 10:30 PM
You mean I will use the media which I have on the cucm server then while performing installation I should select the server as a publisher and after completing the installation I will have to do a restore using the BARS utility ?
09-03-2018 07:18 AM
Yes, you need to have the media for the custom Windows CUCM uses, as well as the media for the CUCM release you have, a BARS backup, and an MCS which supports your CUCM version.
09-03-2018 07:23 AM
If i dont have the BARS backups can I replicate the data from the subscriber ?
09-03-2018 07:25 AM
No, that capability was not added until recent releases. On your version, that means making a copy of everything by hand, and then basically rebuild your cluster.
09-03-2018 07:29 AM
Thanks for the help. So I have the recent BARS backup. After its restored will I have to perform any manual changes ?
09-03-2018 07:35 AM
