Call Manager assistance
Ronit Malhotra
I need to setup 5 phones which should ring at same time
if first phone is busy then it should go to second, followed by third, forth and fifth then to voice mail
Let me know if it can be done
Call Manager version 9.0
Jaime Valencia
Well, you're contradicting yourself, if they need to ring at the SAME TIME, then they're not going to ring in a certain order...
In any case, simply configure a line group, choose the algorithm you actually want, then a hunt list, and a hunt pilot, and that's it.
java
if this helps, please rate
