Call conferencing issue
I need your advise. I have problem with conferencing for any user using Cisco Ip phone and connecting over VPN. So whenever anybody from the office tried to conference with these remote users , the call dropped for these remote users.
Aristide
Vivek Batra
Most of the conference issues are because of incorrect region and device pool settings. Please ensure that the region settings between conference bridge and all participants must allow 64 Kpbs bandwidth (G711) if you're using SW CFB else you must be having IOS with relevant dspfarm configured in it.
- Vivek
9 Replies 9
Jaime Valencia
OK, and what have you checked so far??
What CUCM version??
What phone models???
SW CFB?? HW CFB???
java
if this helps, please rate
Hi Jaime,
I use CUCM version 10.5.
The phones models are: 7841, 7861, 8945, 8861.
I have SW CFB.
Aristide
OK, first thing I can think of, Codec issues, and also, what else have you checked already???
java
Thanks Jaime, ok I will check so far and I will back to you soon.
Thanls Jaime,
It was a codec issue. I have fix it.
Aristide
Dennis Mink
Can you ping it?
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Yes I can ping it. I can make a call also, but I have call conference issue.
Aristide
Vivek Batra
- Vivek
Thanks Vivek,
It works fine now.
