Voicemail in CME is not working
bernsplagata
Question:
My voicemail setup is not working when i dial an extention it is not forwarding to the mailbox nuber instead i get a message that the extension is busy.  Did some debugging and saw a "being refused message"
Configuration:
UC router
ephone-dn  15
number 223
label XXX
description 223-XXX
name XXX
call-forward busy 901
call-forward noan 901 timeout 5
ephone-dn  100
number 5...
description DN to transfer directly to VM
call-forward all 901
telephony-service
voicemail 901
dial-peer voice 901 voip
destination-pattern 901
session protocol sipv2
session target ipv4:192.168.1.2
dtmf-relay sip-notify
codec g711ulaw
no vad
CUE
CUE# show user detail username waseem
Username:           XXX
Full Name:          XXX
First Name:         XXX
Last Name:          XXX
Nickname:           XXX
Phone:              223
Phone(E.164):       5223
Fax:
Email:
Epage:
Language:           systemDefault
GroupMember:        <none>
GroupOwner:         <none>
Privileges:         <none>
CUE# show voicemail mailboxes
OWNER               MSGS NEW SAVE DEL BCST FUTR FAX MSGTIME   MBXSIZE  USED
"XXX"            0    0   0    0   0    0    0   0         300      0 %
DEbug result:
.Jun 26 07:48:43.074: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identifier already present in the list of currently handled calls. It is being refused.
.Jun 26 07:48:43.110: //3645//TCL :/tcl_PutsObjCmd: IP IVR Disconnect Status = RESULT=di_017
.Jun 26 07:48:43.114: //3645//TCL :/tcl_PutsObjCmd:
Call failed.  Play prompt and collect digit
Followed the steps on this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml#verify_one
Thanks in advance
2 Accepted Solutions
Hi Mate - Your call is matching dial-peers 101 and 102. You can verify by running debug voip dialpeer. Shutdown 101 and 102 and then try again it should match 901 dialpeer. Changing 101 and 102 destination pattern to more specific pattern would be the perm fix.
Terry
We are talking CUE not CME.
If you are not sure, do the works at night.
25 Replies 25
Terry Cheema
Hi - the message %CALL_CONTROL-6-CALL_LOOP indicates you are getting a loop. The loop prevention mechanism is kicking in. You need to check your dial-peers. Can you post your full config, with number you are dialing and the ip address of cme and cue.
Terry
Hi Terry,
here is the router config:
UC-2911-GIZ#sh run
Building configuration...
Current configuration : 16580 bytes
! Last configuration change at 14:25:39 GMT+3 Wed Jun 26 2013 by admin
! NVRAM config last updated at 14:25:40 GMT+3 Wed Jun 26 2013 by admin
version 15.1
service password-encryption
hostname UC-2911-GIZ
boot-start-marker
boot-end-marker
enable secret 4 cF67oAbe67PTYT1K/GTqDBLH378FX624kRJwLLqTRKs
no aaa new-model
clock timezone GMT+3 3 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.100.1 10.10.100.10
ip dhcp excluded-address 10.10.200.1 10.10.200.10
ip dhcp pool voice
network 10.10.100.0 255.255.255.0
option 150 ip 192.168.1.1
default-router 10.10.100.1
ip dhcp pool data
network 10.10.200.0 255.255.255.0
default-router 10.10.200.1
no ip domain lookup
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
supplementary-service qsig call-forward
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server expires max 6300 min 3600
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g723r53
codec preference 4 g723r63
codec preference 5 g723ar53
voice class h323 1
  h225 timeout tcp establish 3
voice class custom-cptone STC
dualtone disconnect
  frequency 425
  cadence 250 250
voice class custom-cptone leavetone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone jointone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice register global
mode cme
source-address 192.168.1.1 port 5060
max-dn 300
max-pool 58
load 9951 sip9951.9-3-2SR1-1.loads
timezone 31
tftp-path flash:
create profile sync 0368313124528633
ntp-server 192.168.100.1 mode directedbroadcast
camera
video
voice register dn  1
number 100
name Roland Zielbauer
label Roland Zielbauer
mwi
voice register dn  2
number 110
call-forward b2bua all 111
name Musbah Ayesh
label Musbah Ayesh
mwi
voice register template  1
camera
video
voice register template  2
voice register pool  1
id mac 20BB.C093.ACEE
type 9951
number 1 dn 1
username cisco password cisco
description Roland
codec g711ulaw
no vad
camera
video
voice register pool  2
id mac 20BB.C093.A8D3
type 9951
number 1 dn 2
username musbah password 12345
description 110-Musbah
codec g711ulaw
no vad
camera
video
application
service aa flash:its-CISCO.2.0.1.0.tcl
  paramspace english index 1
  paramspace english language en
  param operator 555
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 299
license udi pid CISCO2911/K9 sn FGL171511HY
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 password 7 0005170B0D552B01063B
username voice privilege 15 secret 4 CeLTLau9JjVldlx2ZHtlQJtX4J90z8e2NMgBH2Y1wJc
redundancy
interface Loopback0
ip address 192.168.1.1 255.255.255.252
ip nat inside
ip virtual-reassembly in
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.252
duplex auto
speed auto
interface ISM0/0
ip unnumbered Loopback0
ip nat inside
service-module ip address 192.168.1.2 255.255.255.252
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.1.1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
interface GigabitEthernet0/1.200
encapsulation dot1Q 200
ip address 10.10.200.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.100.2
ip route 192.168.1.2 255.255.255.255 ISM0/0
tftp-server server
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.12-4-122-02-121029.zz.sgn
tftp-server flash:SCCP69xx.9-3-3-2.loads
tftp-server flash:SCCP69xx.9-3-3-2.zz.sgn
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:dkern9951.100609R2-9-3-2SR1-1.sebn
tftp-server flash:kern9951.9-3-2SR1-1.sebn
tftp-server flash:rootfs9951.9-3-2SR1-1.sebn
tftp-server flash:sboot9951.031610R1-9-3-2SR1-1.sebn
tftp-server flash:sip9951.9-3-2SR1-1.loads
tftp-server flash:skern9951.022809R2-9-3-2SR1-1.sebn
tftp-server flash:apps45.9-3-1ES13.sbn
tftp-server flash:cnu45.9-3-1ES13.sbn
tftp-server flash:cvm45sccp.9-3-1ES13.sbn
tftp-server flash:dsp45.9-3-1ES13.sbn
tftp-server flash:jar45sccp.9-3-1ES13.sbn
tftp-server flash:SCCP45.9-3-1SR2-1S.loads
tftp-server flash:term65.default.loads
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone STC
no battery-reversal
echo-cancel coverage 32
no vad
no comfort-noise
cptone SA
timeouts interdigit 3
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 5
timing hookflash-out 500
description ==TEL#_4812684===
caller-id enable
voice-port 0/0/1
no battery-reversal
no vad
no comfort-noise
cptone SA
timeouts ringing 5
description ==TEL#_4812690===
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
sccp local Loopback0
sccp ccm 192.168.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
associate profile 2 register transprof1
dspfarm profile 2 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 1
associate application SCCP
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
dial-peer voice 101 pots
huntstop
service aa
destination-pattern 9T
port 0/0/0
no sip-register
dial-peer voice 102 pots
huntstop
service aa
port 0/0/1
no sip-register
codec g711ulaw
no vad
sip-ua
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 12
sdspfarm tag 1 confprof1
sdspfarm tag 2 transprof1
conference hardware
video
fxo hook-flash
max-ephones 58
max-dn 300
ip source-address 192.168.1.1 port 2000
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
cnf-file location flash:
cnf-file perphone
load 7937 apps37sccp.1-4-4-0.bin
load 7965 SCCP45.9-3-1SR2-1S.loads
load 6921 SCCP69xx.9-3-3-2
time-zone 31
voicemail 901
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin password admin@giz
web admin customer name cust password cust@giz
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 1..
transfer-pattern 2..
transfer-pattern 3..
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
ephone-dn  2  dual-line
number 101
label Mrs. Antje Svihlik
description Sec to Country Director
name Antje Svihlik
huntstop channel
hold-alert 30 originator
ephone-dn  4  dual-line
number 111
label Jr. Pro Business Dev
description 111-Lulu Al-Khatib
name Lulu Al-Khatib
ephone-dn  5  dual-line
number 112
label Mrs. Heba Hassan
description 112-Heba Hassan
name Heba Hassan
ephone-dn  6  dual-line
number 113
label Mr. Qasem Al-Harbi
description 113-Qasem Al-Harbi
name Qasem Al-Harbi
ephone-dn  7  dual-line
number 200
label Head of Administration
description 200-Sascha Wenzel
name Sascha Wenzel
ephone-dn  8  dual-line
number 210
label Mr. Mohanan Oadath
description 210-Mohanan Oadath
name Mohanan Oadath
ephone-dn  9  dual-line
number 211
label Mr. Bipin Murali
description 211-Bipin Murali
name Bipin Murali
ephone-dn  10  dual-line
number 212
label Vandana Prakash
description 212-Vandana Prakash
name Vandana Prakash
ephone-dn  11  dual-line
number 213
label Sapna Thekkethil
description 213-Sapna Thekkethil
name Sapna Thekkethil
ephone-dn  13  dual-line
number 221
label Jr. HR Manager
description 221-Amr Kassem
name Amr Kassem
ephone-dn  14  dual-line
number 222
label HR Assistant
description 222-Ahmed Samir
name Ahmed Samir
ephone-dn  15
number 223
label Waseem Data Room
description 223-Waseem
name Waseem
ephone-dn  16  dual-line
number 230
label Proc & Subcon Manager
description 230-Hassan Alsalman
name Hassan Alsalman
ephone-dn  17  dual-line
number 231
label Procurement Assistant
description 231-Fahad Al-Zanan
name Fahad Al-Zanan
ephone-dn  18  dual-line
number 240
label Admin & Facility
description Admin & Facility Manager
name Admin & Facility
ephone-dn  19  octo-line
number 241
label Mr. Makki Nuquod
description 241-Receptionist
name Makki Nuquod
ephone-dn  20  dual-line
number 242
label Mr. Manoj Kumar
description 211-Manoj Kumar
name Manoj Kumar
ephone-dn  21  dual-line
number 300
label Mr. Paul Dec
description 300-Paul Dec
name Paul Dec
ephone-dn  22  dual-line
number 301
label name  Dr. Thomas Wanner
description 301-Thomas
name Thomas Wanner
call-forward all 493072614
ephone-dn  23  dual-line
number 302
label Vanessa Gerlach
description PM3
name Vanessa Gerlach
ephone-dn  24  dual-line
number 303
label PM4
description PM4
name PM4
ephone-dn  25  dual-line
number 304
label PM5
description PM5
name PM5
ephone-dn  26  dual-line
number A000
conference ad-hoc
preference 1
no huntstop
ephone-dn  27  dual-line
number A000
preference 2
no huntstop
ephone-dn  28  dual-line
number A000
preference 3
no huntstop
ephone-dn  30  dual-line
number 220
label HR&HM Manager
description 220-Tobias Gerlach
name Mr. Tobias Gerlach
ephone-dn  31  octo-line
number 444
label Conference Room
description 444-Conference Room
name Conference Room
ephone-dn  100
number 5...
ephone  1
conference drop-mode creator
conference add-mode creator
conference admin
mac-address 30F7.0DAD.BBF9
max-calls-per-button 2
type 6921
button  1:21
ephone  2
conference admin
mac-address 30F7.0DAD.A633
type 6921
button  1:6
ephone  3
conference admin
mac-address 30F7.0DAD.C32A
type 6921
button  1:17
ephone  4
conference admin
mac-address B4E9.B08C.0757
type 7965
keep-conference
button  1:2
ephone  5
conference admin
mac-address 30F7.0DAD.BC00
type 6921
keep-conference
button  1:23
ephone  6
conference admin
mac-address 30F7.0DAD.C327
type 6921
keep-conference
button  1:4
ephone  7
conference admin
mac-address 30F7.0DAD.C32D
type 6921
keep-conference
button  1:5
ephone  8
conference admin
mac-address 30F7.0DAD.C384
type 6921
keep-conference
button  1:22
ephone  9
conference admin
mac-address 30F7.0DAD.BC12
type 6921
keep-conference
button  1:13
ephone  10
conference admin
mac-address 30F7.0DAD.BC0A
type 6921
keep-conference
button  1:14
ephone  12
conference admin
mac-address 30F7.0DAD.BBDF
type 6921
keep-conference
button  1:9
ephone  13
conference admin
mac-address 30F7.0DAD.B592
type 6921
keep-conference
button  1:20
ephone  14
conference admin
mac-address 30F7.0DAD.AF86
type 6921
keep-conference
button  1:8
ephone  15
conference admin
mac-address 30F7.0DAD.C1EA
type 6921
keep-conference
button  1:10
ephone  16
conference admin
mac-address 30F7.0DAD.B0DC
type 6921
keep-conference
button  1:11
ephone  17
conference admin
mac-address 30F7.0DAD.B1B4
keep-conference
button  1:16
ephone  18
conference admin
mac-address 30F7.0DAD.BBD6
type 6921
keep-conference
button  1:30
ephone  19
conference admin
mac-address 30F7.0DAD.AFD3
type 6921
keep-conference
button  1:19
ephone  20
conference admin
mac-address 30F7.0DAD.B0B5
type 6921
keep-conference
button  1:7
ephone  21
conference admin
mac-address 30F7.0DAD.AF77
username "waseem"
type 6921
keep-conference
button  1:15
ephone  22
conference admin
mac-address 0004.F2F5.6912
type 7937
keep-conference
button  1:31
ephone-hunt 1 sequential
pilot 555
list 101, 111, 112
timeout 15, 15, 15
no-reg pilot
statistics collect
description Operator
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
ntp server 192.168.100.1
ntp server 192.168.1.50
end
Here is CUE config
se-192-168-1-2# sh run
Generating configuration:
clock timezone Asia/Riyadh
hostname se-192-168-1-2
line console
  length 0
system language preferred "en_GB"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/h        sEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfG        WTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site name local
site-hostname 10.10.100.1
web credentials hidden "FMTJhCv8ZiubPYIMNk0k309OYQAQ7xteSd8ZZNgd+Y9J3xlk2B35j0n        fGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end site
license agent max-sessions 9
privilege ViewPrivateList create
privilege ManagePrompts create
privilege ViewHistoricalReports create
privilege vm-imap create
privilege ManagePublicList create
privilege broadcast create
privilege manage-users create
privilege manage-passwords create
privilege local-broadcast create
privilege ViewRealTimeReports create
groupname Broadcasters create
username voice create
username antje create
username cisco create
username waseem create
username admin create
privilege ViewPrivateList description "Privilege to view private list"
privilege ManagePrompts description "Privilege to create, modify, or delete syst        em prompts"
privilege ViewHistoricalReports description "Privilege to view historical report        s"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP c        lient"
privilege ManagePublicList description "Privilege to manage public lists"
privilege broadcast description "Privilege to send local or remote broadcast mes        sages"
privilege manage-users description "Privilege to create, modify, and delete user        s and groups"
privilege manage-passwords description "Privilege to reset user passwords"
privilege local-broadcast description "Privilege to send local broadcast message        s"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege ViewPrivateList operation voicemail.lists.private.view
privilege ManagePrompts operation prompt.modify
privilege ManagePrompts operation system.debug
privilege ViewHistoricalReports operation report.historical.view
privilege vm-imap operation voicemail.imap.user
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege broadcast operation broadcast.remote
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege manage-users operation user.pin
privilege manage-users operation user.mailbox
privilege manage-users operation user.password
privilege manage-users operation user.configuration
privilege manage-users operation user.notification
privilege manage-users operation system.debug
privilege manage-users operation group.configuration
privilege manage-users operation user.remote
privilege manage-passwords operation user.pin
privilege manage-passwords operation user.password
privilege manage-passwords operation system.debug
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege ViewRealTimeReports operation report.realtime
groupname Administrators member voice
groupname Administrators member cisco
groupname Administrators member admin
groupname Broadcasters privilege broadcast
username antje phonenumber "101"
username waseem phonenumber "223"
username antje phonenumberE164 "5101"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application aa aa
description "aa"
enabled
maxsessions 2
script "aa.aef"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "dialByExtnAnytimeInputLength" "3"
parameter "operExtn" "555"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "true"
parameter "dialByFirstName" "true"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "true"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "3"
end application
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 10
script "aa.aef"
parameter "dialByExtnAnytime" "true"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 10
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 10
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 10
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-192-168-1-2"
end reporting
ccn subsystem email
end subsystem
ccn subsystem fax
end subsystem
ccn subsystem sip
gateway address "192.168.1.1"
mwi sip sub-notify
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 901
application "voicemail"
enabled
locale "en_GB"
maxsessions 10
end trigger
ccn trigger sip phonenumber 905
application "promptmgmt"
enabled
locale "en_GB"
maxsessions 1
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail operator telephone 902
banner login append "Unauthorized access to this device is forbidden and will be "
banner login append "prosecuted by law. By accessing this system, you agree that your "
banner login append "actions may be monitored if unauthorized usage is suspected"
end
THanks..
Terry
Hi Terry,
9T right? let me change some things...and will get back at you with the results
Yes - 9T will catch everything starting with 9
HI Terry,
Managed to hit the VM prompt (thanks to you)...bu now i have an issue...now adding mailboxes via CLI:
I get this error:
se-192-168-1-2(config)# voice mailbox owner waseem
Out of memory: kill process 2402 (startup.sh) score 160571 or a child
Killed process 2403 (java)
Out of memory: kill process 2402 (startup.sh) score 139493 or a child
Killed process 2404 (logerr)
/bin/startup.sh: line 1:  2403 Killed                  /usr/wfavvid/run-wfengine.sh 2>&1
      2404                       | logerr ccn server output
MONITOR EXITING...
SAVE TRACE BUFFER
Jun 26 15:48:39 localhost err_handler:   CRASH appsServices startup startup.sh System has crashed. The trace buffer information is stored in the file "atrace_save.log". You can upload the file using "copy log" command
Out of memory: kill process 2399 (startup.sh) score 102579 or a child
Killed process 2400 (java)
Out of memory: kill process 3232 (postmaster) score 89685 or a child
Killed process 3232 (postmaster)
as reading some stuff over the forums..seems a corrupt CUE?
Hello bernsplagata ,
Would appreciate if you can share how did you ended up with your problem.
I am running into the same problem, during cue boot i get following error:
SAVE TRACE BUFFER
Dec 30 12:37:00 localhost err_handler:   CRASH appsServices startup startup.sh System has crashed. The trace buffer information is stored in the file "atrace_save.log". You can upload the file using "copy log" command
INIT: Sending processes the TERM signal
Terry Cheema
Hi Mate,
Not a problem. Your overlapping dial-peers were creating a loop. Loop control saved from CPU going high/crashing.
Regards to your memory issue, it appears to be a memory leak. Can you try reloading the CUE and the router itself?
Please do rate the helpful posts.
Terry
HI Terry,
I will reload both CUE and router...and will get back to hoe things will turn out.  Thanks.
Hi Terry,
I have restarted both router and CUE but i get the same error message when im configuring the user mailbox:
Out of memory: kill process 2413 (startup.sh) score 167031 or a child
Killed process 2414 (java)
Out of memory: kill process 2413 (startup.sh) score 139472 or a child
Killed process 2415 (logerr)
/bin/startup.sh: line 1:  2414 Killed                  /usr/wfavvid/run-wfengine        .sh 2>&1
      2415                       | logerr ccn server output
MONITOR EXITING...
SAVE TRACE BUFFER
Jun 26 16:30:06 localhost err_handler:   CRASH appsServices startup startup.sh S        ystem has crashed. The trace buffer information is stored in the file "atrace_sa        ve.log". You can upload the file using "copy log" command
Out of memory: kill process 2410 (startup.sh) score 102155 or a child
Killed process 2411 (java)
Out of memory: kill process 3222 (postmaster) score 89792 or a child
Killed process 3222 (postmaster)
paolo bevilacqua
Update CUE software and check again.
Hi Paolo,
that could be tricky...but if its the only way then i canot escape that...i got this box preloaded...licenses were applied by them. anyways will check out your suggestion and will get back to you once done..thanks again...
Updating software does not invalidate licenses.
+5 Paolo. Bernsplagata let us know how you go.
