Call Manager can't find 6509 CMM resources
gwhuang5398
Level 2
Level 2
I configured 6509 CMM module media card for a conferencing resource and a transcoder, then I inserted them into Call Manager as media resource. But neither was able to register with a call manager. There's no issue with routing and reaching each other's IP addresses.
Any suggestions?
Gary
6 Replies 6
gogasca
Level 10
Level 10
Please make sure you have followed this guide:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123limit/123x/123xy8/gtcmm.htm#wp1285052
IP connectivity between CMM and CCM is fine right?
If all is good please paste your config and an screenshot of CCM CFB config
I followed all the procedures in that document. All the IP connectivities are good. I can ping the CMM intrefaces (G1/0, Fa1/0. Fa3/0) anywhere on the network. Can also ping CCMs from the CMM.
Here is the relevant CMM config:
mediacard 2
resource-pool nokct1vg01a-conf dsps 4
mediacard 4
resource-pool nokct1vg01a-trans dsps 4
sccp local GigabitEthernet1/0
sccp ccm 172.28.4.5 identifier 1
sccp ccm 172.28.105.5 identifier 2
sccp ccm 10.132.189.5 identifier 3
sccp
sccp ccm group 801
associate ccm 3 priority 3
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 2 register MTP0018b983f9aa
associate profile 1 register CFB0018b983f9a8
dspfarm
dspfarm profile 1 conference adhoc
codec g711ulaw packetization-period 30
codec g711alaw packetization-period 30
codec g729r8 packetization-period 30
codec g729ar8 packetization-period 30
codec g723r63 packetization-period 30
codec g723r53 packetization-period 30
associate resource-pool nokct1vg01a-conf
dspfarm profile 2 transcode
associate resource-pool nokct1vg01a-trans
On CCM:
Service > Media Resource > Conference Bridge.
Then "Add New Conference Bridge":
Conference Bridge Type = Conference Bridge (WS-SVC-CMM).
MAC Address = MAC of CMM Int G1/0
Subunit = 2 (for media card 2)
Device Pool = an existing device pool
Maximum Capacity = 128
But CCM can't find the resource.
On CMM, also showing "not registered with CCM":
NOKCT1VG01A#sh sccp
SCCP Admin State: UP
Gateway IP Address: 10.132.26.67, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.28.4.5, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Call Manager: 172.28.105.5, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 2
Call Manager: 10.132.189.5, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 3
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 128, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 30
Supported Codec: g729br8, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 30
Supported Codec: g729abr8, Maximum Packetization Period: 30
Supported Codec: g723_6.3, Maximum Packetization Period: 30
Supported Codec: g723_5.3, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 172.28.4.5, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Supported Codec: t.38 fax, Maximum Packetization Period: 20
When you configure the CFB in CCM.
CCMAdmin will automatically generate a name for CMM conference bridge.
You are using another name:
So please go to CCM Admin and check which is the device name for the CFB and fro the MTP
will be sth like this (MAC will change of course):
M020003feac9852 for MTP
C010003FEAC9853 for CFB
I still couldn't get the CMM registered with CMM Admin. Here is what I have done. Can you tell me if I had something incorrect?
1. This is a new CMM in a new 6509. I configured both of them and all interfaces are up.
2. CMM has a media card in its slot 2. I configured it as conference bridge and media card 4 as transcoder.
3. The CMM also has a T1 PRI card but right now there are no live T1 circuits into it.
4. The CMM has a CCM group with 3 CCM hosts in it, one primary and 2 redundant. SCCP is shown as ACTIVE now.
5. I didn't configure CCM Admin to add the conference bridge and transcoder. I thought the CCM should be able to find the resources once they are registered. But CMM was not able to get registered. Here is CMM "sh sccp".
6. Then I tried to insert the resources into CCM Admin, but the CMM still couldn't be found by the CCM Admin.
My question is: is it sufficient to just configure the CMM and let it to register with CCM on its own or do I need to configure bot CMM and CCM Admin at the same time? Is "no live T1 circuit" possibly a factor to cause the registration problem?
Thanks a lot
Gary
You need to configure both CMM and CCM Admin at the same time. So CCM recognizes it as a valid device in its DB.
There's an option for auto-reg but discard it.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123limit/123x/123xy8/gtcmm.htm#wp1245747
Thanks. I added CMM to the CCM Admin and they got registered with CCM.
