02-04-2012 07:09 AM - edited 03-16-2019 09:24 AM
Any available cisco tools or any plugin or any third partly tool available for notifying the changes done in communication manager.
Changes like: Systems Elements: Servers, Device Pools, License, etc.
Media Resources: Conference Bridges, Transcoders, MTP, etc.
Route Plan: Route / Translation Patterns, Partitions, etc.
Routing Devices: Gateways, MGCP PRI & Analog Endpoints, etc.
Voice Mail: Ports, Pilots, Profiles
Phones: Lines, AppLoad, Switchports, etc
Thanks & Regards,
M.Mohamed Raffiudeen...
Solved! Go to Solution.
02-04-2012 07:47 AM
Are you looking for audit logs? If so, have you seen this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_6_1/admin/saaulog.html
HTH,
Chris
02-04-2012 07:47 AM
HTH,
Chris
02-04-2012 08:23 AM
Thanks Chris,
I was looking for the same...
We have many ccm administrators with different access privilege and we are unable to trace the specific changes made by the admins. Sometimes it creats havoc in our voice network. This will help us to monitor the changes made and rollback will be easier...
02-07-2012 04:24 AM
Audit log setup is available in our CUCM ver 8.5. How to enable the same in ver 6.1?
Thanks & Regards,
Raffi...
02-07-2012 06:20 AM
Yeah, this was added in CUCM 7.X, so this would not be available in prior versions, sorry.
Chris
02-08-2012 01:13 AM
Hi Chris,
Thanks for the valuable information...
Raffi...
