Call Manager Extension List
pharden
i am trying to print out a list of extenstions. i need to covert a group (Device Pool) of extensions to new DID's
I went to Unified Reports, however can not find the correct report.  I went to Bulk Admin and update phones, however Print screen and copy/paste will not print them all. Any Idea's
Rob Huffman
Hi Phillip,
From CUCM admin try Call Routing > Route Plan Report and once it loads
up look at the top right hand corner of the page for "View in File" this will allow
you to save a copy in .csv format
Cheers!
Rob
6 Replies 6
Jonathan Schulenberg
Use the Import/Export section of BAT which is available in CUCM 8 and possibly 7. You can pull out all of the DNs into a CSV file and then just sort/filter it down to those in the range you want.
Rob Huffman
Hi Phillip,
Cheers!
Rob
Nice catch Rob. +5
Jonathan
Right back at ya my friend +5
Cheers!
Rob
You guys ROCK!!!
Thank You
PH
Rob Huffman
Hi Phillip,
You are always welcome my friend
Cheers!
Rob
